Superior performance
You get the ultimate in scanning performance - period. Your workers can scan virtually any 1D or 2D electronic or printed barcode in any condition, as fast as they can pull the trigger. With more working range, it's easy to capture barcodes, that are farther away. Even if barcodes are under shrink-wrap or damaged, dirty or poorly printed, no problem - this intelligent scanner can handle it all. -
Ultra-rugged design
The manufacturing plant floor is as tough as its gets - and the cost of unplanned downtime on the production line is astronomical. The scanners are dust-tight, spray-proof and waterproof to IP67, with an IP65 sealed cradle for a complete rugged solution. -
Unrivaled manageability
You can remotely configure and upgrade your scanners, format data properly for instant transmission into your business applications, monitor battery statistics for your cordless models and more.
- Zebra DS3608-SR - barcode scanner
- Barcode scanner - handheld - USB - decoded
- Black, green
- Minimum Bar Width
- 5 mil
- Scan Element Type
- 2D imager
- Connectivity Technology
- Wired
- 7.6 cm x 13.2 cm x 18.5 cm
- 305 g
- 3-year warranty
- Black, green
Barcode
- Interface Type
- USB
- Minimum Bar Width
- 5 mil
- Scan Element Type
- 2D imager
- Max Working Distance
- 35 cm
- Skew (Degrees)
- 50
- Pitch (Degrees)
- 60
- Print Contrast Signal (PCS)
- 25%
- Decode Capability
- EAN/JAN, Code 93, Code 39, UCC/EAN-128, NW-7, IATA, GS1 DataBar, QR code, MaxiCode, Bookland, Code 32, Code 39 Full ASCII, EAN/JAN-8, EAN/JAN-13, Discrete 2 of 5, MicroPDF417, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, PLANET, Australian Post, Japanese Post, Code 128 Full ASCII, Code 39 Trioptic, Dutch Post, UK Post
- TTL Decoding
- Decoded
- Wired
- OK Notification
- Beeper, LED indicator
- Reduced Space Symbology (RSS), Two-Position Smart Focus, rugged
- 1 x USB
- Cables Included
- 1 x USB cable - external
- EN 60950, IEC950, UL 1950, IEC 60529 IP65, ICES-003 Class B, FCC Part 15 B, EMC, RoHS, CSA C22.2 No. 950
- 7.6 cm
- 13.2 cm
- 18.5 cm
- 305 g
- Limited warranty - 3 years
- -30 °C
- 50 °C
- 5 - 95% (non-condensing)
