Zebra DS3608-SR USB Kit Rugged Green Vibration
Quicklinx: CGTGWS00 Mfr#: DS3608-SR3U4600VZW
Type: Barcode scanner
Form Factor: Handheld
Compatibility: PC
£308.98 ex VAT
£370.77 inc VAT
Marketing description is not available.
  • Superior performance
    You get the ultimate in scanning performance - period. Your workers can scan virtually any 1D or 2D electronic or printed barcode in any condition, as fast as they can pull the trigger. With more working range, it's easy to capture barcodes, that are farther away. Even if barcodes are under shrink-wrap or damaged, dirty or poorly printed, no problem - this intelligent scanner can handle it all.
  • Ultra-rugged design
    The manufacturing plant floor is as tough as its gets - and the cost of unplanned downtime on the production line is astronomical. The scanners are dust-tight, spray-proof and waterproof to IP67, with an IP65 sealed cradle for a complete rugged solution.
  • Unrivaled manageability
    You can remotely configure and upgrade your scanners, format data properly for instant transmission into your business applications, monitor battery statistics for your cordless models and more.
Zebra DS3608-SR - barcode scanner
Barcode scanner - handheld - USB - decoded
Black, green
Minimum Bar Width
5 mil
Scan Element Type
2D imager
Wired
7.6 cm x 13.2 cm x 18.5 cm
305 g
3-year warranty
Black, green
Barcode
Interface Type
USB
Minimum Bar Width
5 mil
Scan Element Type
2D imager
Max Working Distance
35 cm
Skew (Degrees)
50
Pitch (Degrees)
60
Print Contrast Signal (PCS)
25%
Decode Capability
EAN/JAN, Code 93, Code 39, UCC/EAN-128, NW-7, IATA, GS1 DataBar, QR code, MaxiCode, Bookland, Code 32, Code 39 Full ASCII, EAN/JAN-8, EAN/JAN-13, Discrete 2 of 5, MicroPDF417, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, PLANET, Australian Post, Japanese Post, Code 128 Full ASCII, Code 39 Trioptic, Dutch Post, UK Post
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator
Reduced Space Symbology (RSS), Two-Position Smart Focus, rugged
1 x USB
1 x USB cable - external
EN 60950, IEC950, UL 1950, IEC 60529 IP65, ICES-003 Class B, FCC Part 15 B, EMC, RoHS, CSA C22.2 No. 950
7.6 cm
13.2 cm
18.5 cm
305 g
Limited warranty - 3 years
-30 °C
50 °C
5 - 95% (non-condensing)
CGTG Zebra Adjustable Intellistand In Stock £59.21
Compatibility: PC
Brand: Zebra
