Zebra Direct Thermal Transfer Printer
Quicklinx: 89FPWS00 Mfr#: GX42-102520-000
The direct thermal/thermal transfer GX420t has the easiest ribbon-loading system around. It produces 203-dpi print resolution at speeds up to 6 inches per second.
  • Always a perfect fit
    Zebra's G-Series compact desktop printers for print widths up to 4 inches deliver best-in-class speed and performance. The G-Series printers are reliable, durable, and flexible to fit almost any low- to mid-volume printing application and budget.
  • Fitting choices
    The premier GX model supports a variety of industries and applications with the widest range of features. Zebra's G-Series printer is a smart investment, and always a perfect fit.
Zebra GX420t - label printer - B/W - direct thermal / thermal transfer
Printer Type
Label printer - direct thermal / thermal transfer - B/W
2.1 kg
United Kingdom, Europe
Max Media Size
Roll (10.8cm)
Min Media Size (Custom)
19 mm x 9.7 mm
Max Media Size (Custom)
108 mm x 991 mm
Print Speed
Up to 152 mm/sec - B/W
Max Resolution (B&W)
203 dpi
Parallel, USB, serial
RAM Installed (Max)
8 MB SDRAM
Flash Memory Installed (Max)
4 MB (68 MB)
Language Simulation
ZPL, ZPL II, EPL2
Barcodes
Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Code 2 of 5, UPC, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Japanese Post, Plessey, MacroPDF417, EAN-14, Code 128B, Code 128C, German Post, MSI-3, Code 128A
Media Type
Labels, continuous forms, fanfold paper, tag stock
Microsoft Certification
Compatible with Windows 7
1-year warranty
19.4 cm x 25.4 cm x 19.1 cm
Printer Type
Label printer - direct thermal / thermal transfer - monochrome
Printer
Print Speed
Up to 152 mm/sec - B/W - 203 dpi
Wired
203 dpi
Language Simulation
ZPL, ZPL II, EPL2
Fonts Included
16 x bitmapped , 1 x scalable
Barcodes
RAM
RAM Installed (Max)
8 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
4 MB (installed) / 68 MB (max)
Media Handling
Media Type
Max Media Size
Roll (10.8cm)
19 mm x 9.7 mm
108 mm x 991 mm
Media Sizes
Roll (1.9 - 10.8 cm)
Max Printing Width
104 mm
Max Printing Length
991 mm
Media Thickness Range
0.08 mm - 0.2 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm, 12.7 mm, 37.1 mm
Media Feeders
1 x manual - 1 roll - Roll (10.8cm)
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B , 1 x parallel - 36 PIN Centronics
Cleaning pen
1 x USB cable
TUV, VCCI, C-Tick, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, CCC, FCC Part 15
Power adapter - external
Frequency Required
50/60 Hz
Power Factor Correction
Software Included
Drivers & Utilities, ZebraDesigner
Limited warranty - 1 year
5 °C
41 °C
10 - 90% (non-condensing)
19.4 cm
25.4 cm
19.1 cm
2.1 kg
Weight (Shipping)
4.1 kg
Ink (8)
89FP Zebra RIBBON WAX 2300 110MM X 74M(Box of 12) In Stock £33.59
89FP Zebra 1ROLL ZSLCT 2000D 102 X 64 MM 12 rolls In Stock £189.35
89FP Zebra Z-PERF 1000D 80 RECEIPT 102MM 100 METERS C-25MM BOX OF 12 In Stock £102.80
89FP Zebra Z-Select 2000D 57x32mm In Stock £117.80
89FP Zebra 12 ROLLS Z-SLCT 2000D 51X25MM In Stock £111.19
89FP Zebra Z-Select 2000D Permanent Adhesive Labels In Stock £115.01
89FP Zebra Ribbon Wax/Resin 110mm x 74m In Stock £50.68
89FP Zebra Direct 1100 Perforated Matte Permanent Rubber Adhesive Paper - 16440 pcs. In Stock £125.77
Other bundles (1)
89FP Zebra 3200 Premium Wax/Resin (12 Pack) - Black In Stock £29.63
