The direct thermal/thermal transfer GX420t has the easiest ribbon-loading system around. It produces 203-dpi print resolution at speeds up to 6 inches per second.
Always a perfect fit
Zebra's G-Series compact desktop printers for print widths up to 4 inches deliver best-in-class speed and performance. The G-Series printers are reliable, durable, and flexible to fit almost any low- to mid-volume printing application and budget. -
Fitting choices
The premier GX model supports a variety of industries and applications with the widest range of features. Zebra's G-Series printer is a smart investment, and always a perfect fit.
- Zebra GX420t - label printer - B/W - direct thermal / thermal transfer
- Printer Type
- Label printer - direct thermal / thermal transfer - B/W
- 2.1 kg
- Localisation
- United Kingdom, Europe
- Max Media Size
- Roll (10.8cm)
- Min Media Size (Custom)
- 19 mm x 9.7 mm
- Max Media Size (Custom)
- 108 mm x 991 mm
- Print Speed
- Up to 152 mm/sec - B/W
- Max Resolution (B&W)
- 203 dpi
- Interface
- Parallel, USB, serial
- RAM Installed (Max)
- 8 MB SDRAM
- Flash Memory Installed (Max)
- 4 MB (68 MB)
- Language Simulation
- ZPL, ZPL II, EPL2
- Barcodes
- Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Code 2 of 5, UPC, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Japanese Post, Plessey, MacroPDF417, EAN-14, Code 128B, Code 128C, German Post, MSI-3, Code 128A
- Media Type
- Labels, continuous forms, fanfold paper, tag stock
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 19.4 cm x 25.4 cm x 19.1 cm
- Printer Type
- Label printer - direct thermal / thermal transfer - monochrome
- Localisation
Printer
- Print Speed
- Up to 152 mm/sec - B/W - 203 dpi
- Connectivity Technology
- Wired
- Interface
- 203 dpi
- ZPL, ZPL II, EPL2
- Fonts Included
- 16 x bitmapped , 1 x scalable
- Barcodes
RAM
- 8 MB
- Technology / Form Factor
- SDRAM
Flash Memory
- Flash Memory
- 4 MB (installed) / 68 MB (max)
Media Handling
- Media Type
- Max Media Size
- Roll (10.8cm)
- 19 mm x 9.7 mm
- 108 mm x 991 mm
- Media Sizes
- Roll (1.9 - 10.8 cm)
- Max Printing Width
- 104 mm
- Max Printing Length
- 991 mm
- Media Thickness Range
- 0.08 mm - 0.2 mm
- Roll Maximum Outer Diameter
- 127 mm
- Roll Core Diameter
- 25.4 mm, 12.7 mm, 37.1 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (10.8cm)
- Connections
- 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B , 1 x parallel - 36 PIN Centronics
- Included Accessories
- Cleaning pen
- Cables Included
- 1 x USB cable
- TUV, VCCI, C-Tick, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, CCC, FCC Part 15
- Power Device
- Power adapter - external
- Frequency Required
- 50/60 Hz
- Power Factor Correction
- Software Included
- Drivers & Utilities, ZebraDesigner
- Limited warranty - 1 year
- 5 °C
- 41 °C
- 10 - 90% (non-condensing)
- 19.4 cm
- 25.4 cm
- 19.1 cm
- 2.1 kg
- Weight (Shipping)
- 4.1 kg
Ink (7)
Zebra 1ROLL ZSLCT 2000D 102 X 64 MM 12 rolls | In Stock | £188.91 |
Zebra Z-PERF 1000D 80 RECEIPT 102MM 100 METERS C-25MM BOX OF 12 | In Stock | £102.53 |
Zebra Z-Select 2000D 57x32mm | In Stock | £117.52 |
Zebra 12 ROLLS Z-SLCT 2000D 51X25MM | In Stock | £110.92 |
Zebra Z-Select 2000D Permanent Adhesive Labels | In Stock | £114.74 |
Zebra Ribbon Wax/Resin 110mm x 74m | In Stock | £50.56 |
Zebra Direct 1100 Perforated Matte Permanent Rubber Adhesive Paper - 16440 pcs. | In Stock | £125.48 |
Other bundles (2)
Zebra 3200 Premium Wax/Resin (12 Pack) - Black | In Stock | £29.56 |
Zebra Z-Perform 1000D - 880191-038D Economy direct thermal paper l | In Stock | £157.56 |
