At 2.2" (56 mm), the direct thermal and thermal transfer TLP 2824 bar code label printer is ideal for retail and other label applications. The TLP 2824 redefines the compact printer class. It fits into areas other printers cannot, withstanding rough handling and integrating easily into a wide range of applications. A 5" (127 mm) media roll capacity and clear media window optimize productivity, while a maximum print speed of 4" (102 mm) per second enables fast job processing.
The TLP 2824 excels in delivering printing solutions for business and professional offices, including retail point of sale, shelf labeling, product marking, healthcare specimen labeling and patient tracking, inventory and asset management, small office or home office mailing, shipping, and file folder labeling.
- Zebra TLP 2824 - label printer - B/W - thermal transfer
- Printer Type
- Label printer - thermal transfer - B/W
- 1.6 kg
- Max Media Size
- Roll (6 cm)
- Max Media Size (Custom)
- 60 mm
- Print Speed
- Up to 102 mm/sec - B/W
- Max Resolution (B&W)
- 203 dpi
- Interface
- Parallel
- RAM Installed (Max)
- 128 KB (256 KB)
- Flash Memory Installed (Max)
- 512 KB (1 MB)
- Language Simulation
- EPL2
- Barcodes
- Code 93, Code 39, UCC/EAN-128, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, GS1 DataBar-14, MacroPDF417
- Media Type
- Labels, continuous forms, thermal paper, fanfold paper, tag stock
- Microsoft Certification
- Works with Windows Vista
- 14 cm x 24.1 cm x 17.8 cm
- Printer Type
- Label printer - thermal transfer - monochrome
Printer
- Print Speed
- Up to 102 mm/sec - B/W - 203 dpi
- Connectivity Technology
- Wired
- Interface
- Parallel
- 203 dpi
- EPL2
- Fonts Included
- 5 x bitmapped
- Barcodes
RAM
- 128 KB / 256 KB (max)
Flash Memory
- Flash Memory
- 512 KB (installed) / 1 MB (max)
Media Handling
- Media Type
- Max Media Size
- Roll (6 cm)
- 60 mm
- Media Sizes
- Roll (6 cm)
- Max Printing Width
- 56 mm
- Media Thickness Range
- 0.075 mm - 0.18 mm
- Roll Maximum Outer Diameter
- 127 mm
- Roll Core Diameter
- 25.4 mm, 38 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (6 cm)
- Connections
- 1 x parallel
- Included Accessories
- Cutter
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- UL, VCCI, GOST, NOM, CCC, FCC, C-ETL
- Power Device
- Power adapter - external
- Frequency Required
- 50/60 Hz
- Software Included
- Drivers & Utilities
- 5 °C
- 41 °C
- 10 - 90%
- 14 cm
- 24.1 cm
- 17.8 cm
- 1.6 kg
