Zebra Desktop TLP 2824 Direct
Quicklinx: 78DMWS00 Mfr#: 2824-11222-0001
At 2.2" (56 mm), the direct thermal and thermal transfer TLP 2824 bar code label printer is ideal for retail and other label applications. The TLP 2824 redefines the compact printer class. It fits into areas other printers cannot, withstanding rough handling and integrating easily into a wide range of applications. A 5" (127 mm) media roll capacity and clear media window optimize productivity, while a maximum print speed of 4" (102 mm) per second enables fast job processing.
The TLP 2824 excels in delivering printing solutions for business and professional offices, including retail point of sale, shelf labeling, product marking, healthcare specimen labeling and patient tracking, inventory and asset management, small office or home office mailing, shipping, and file folder labeling.
Zebra TLP 2824 - label printer - B/W - thermal transfer
Printer Type
Label printer - thermal transfer - B/W
1.6 kg
Max Media Size
Roll (6 cm)
Max Media Size (Custom)
60 mm
Print Speed
Up to 102 mm/sec - B/W
Max Resolution (B&W)
203 dpi
Parallel
RAM Installed (Max)
128 KB (256 KB)
Flash Memory Installed (Max)
512 KB (1 MB)
Language Simulation
EPL2
Barcodes
Code 93, Code 39, UCC/EAN-128, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, GS1 DataBar-14, MacroPDF417
Media Type
Labels, continuous forms, thermal paper, fanfold paper, tag stock
Microsoft Certification
Works with Windows Vista
14 cm x 24.1 cm x 17.8 cm
Printer Type
Label printer - thermal transfer - monochrome
Printer
Print Speed
Up to 102 mm/sec - B/W - 203 dpi
Wired
Parallel
203 dpi
Language Simulation
EPL2
Fonts Included
5 x bitmapped
Barcodes
RAM
RAM Installed (Max)
128 KB / 256 KB (max)
Flash Memory
Flash Memory
512 KB (installed) / 1 MB (max)
Media Handling
Media Type
Max Media Size
Roll (6 cm)
60 mm
Media Sizes
Roll (6 cm)
Max Printing Width
56 mm
Media Thickness Range
0.075 mm - 0.18 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm, 38 mm
Media Feeders
1 x manual - 1 roll - Roll (6 cm)
1 x parallel
Cutter
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
UL, VCCI, GOST, NOM, CCC, FCC, C-ETL
Power adapter - external
Frequency Required
50/60 Hz
Software Included
Drivers & Utilities
5 °C
41 °C
10 - 90%
14 cm
24.1 cm
17.8 cm
1.6 kg
