Zalman ZM-VE500 2.5 S-ATA USB 3.0 Silver
Quicklinx: CCM3WS00 Mfr#: ZM-VE500 (SILVER)
The ZM-VE500 provides and advanced solution to connect a SATA device to a USB 3.0 host with an integrated 32-bit microprocessor and embedded SRAM. To provide a high performance with a real-time hardware encryption based on AES256bit architecture. Through virtual drive technology is available in one off external hard disk drive solutions.
ZALMAN ZM-VE500 - storage enclosure - SATA 6Gb/s - USB 3.0
Storage enclosure - external
Bus Type
USB 3.0
Silver
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 6Gb/s
Supported Devices
Hard drive, solid state drive
Product Material
Polycarbonate, acryl, aluminium alloy
Power Source
USB bus
Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/8.1/10
8.08 cm x 14.6 cm x 1.4 cm
91 g
2.5"
Host Bus
USB 3.0
Product Material
Silver
Storage Controller
SATA 6Gb/s
Supported Devices
Bays
1 x internal - 2.5"
1 x USB 3.0 - Micro-USB Type B
1 x USB 3.0 - 9 pin USB Type A
Pouch
1 x USB 3.0 cable - external
Status LCD display, password security, virtual ODD function mode, touchpad
Mounting Kit
Included
AES-256
Power Source
USB bus
8.08 cm
14.6 cm
1.4 cm
91 g
