Zagg Pro Stylus 2 for iPad Pro 11-inch/iPad Pro 12.9-inch - White
Quicklinx: J9DTWS00 Mfr#: 109912135
£38.02 ex VAT
£45.62 inc VAT
Pro Stylus 2 helps you do more with your tablet and even makes using your phone easier. Use the fine tip to draw and write, and use the round, capacitive end to swipe. Pro Stylus 2 helps you increase your accuracy, edit photos precisely, and avoid fingerprint smudges on your screen. Tilt recognition and palm rejection technology allow you to create nuanced, pixel-perfect artwork and mark-up documents quickly and efficiently. Pro Stylus 2 charges wirelessly and has a long-lasting battery.
ZAGG Pro Stylus 2 - active stylus - white
Active stylus
White
7.2 cm x 2.7 cm x 21 cm
109 g
LED indicator, Palm Rejection Technology, tilt sensitive, magnetic attachment area, replaceable tip, automatic power off, wireless charging
Active stylus
7.2 cm
2.7 cm
21 cm
109 g
White
Input Device
USB-C charging cable, wireless charging pad, replacement pen tip
Qi
Run Time (Up To)
6.5 hours
Brand: Zagg
