Zagg Pro Keys for 10.9-inch iPad Wireless, Bluetooth, QWERTY Grey
Quicklinx: J9DWWS00 Mfr#: 103410814
More than 50 In Stock
£49.08 ex VAT
£58.89 inc VAT
Wireless Keyboard and Detachable Case
Unleash the productive capabilities of your tablet with the Pro Keys wireless keyboard & detachable case. It has everything you need to make any surface an effective workspace. We've developed a Pro keyframe with smooth, precise key travel for fast, accurate touch typing. The case allows your stylus to attach magnetically to your iPad. And we've included all the extras for an ideal user experience including forward-facing speaker cutouts, backlit keys, and an adjustable stand. Transform your tablet into a lightweight, portable workstation so you can work from anywhere. We've optimized Pro Keys with accessories that enhance your tablet's capabilities, making it truly user-friendly and efficient. The keyboard and case detach to accommodate different uses and environments. The holder for Apple Pencil keeps it, or any other stylus, close at-hand for when inspiration strikes.Our new Pro keyframe design provides optimal key travel for clean, precise keystrokes and an easy, comfortable typing experience. The backlit keys, in seven different colors, make typing in low-light conditions easy. The durable polycarbonate case has a rigid core, rubberized edges and button covers, and corner bumpers, all of which combine to provide 6.6 (2m) of drop protection. The lightweight design fits easily in your bag. The Pro Keys wireless keyboard pairs with two devices simultaneously, like a tablet and your phone, so you can toggle back and forth between them.Type for up to a year before recharging the battery. Keyboard automatically turns off when folded backwards against the tablet. The sleep/wake function helps preserve battery life when keyboard is not in use.*Based on regular use of one hour per day.
ZAGG Pro Keys - keyboard and folio case (detachable case) - QWERTY - UK Input Device
Keyboard and folio case
Backlit
7 colours
Bluetooth
Wireless
Localization and Layout
QWERTY UK
Case Material
Polycarbonate
671 g
Apple 10.9-inch iPad (10th generation)
Backlit
7 colours
Bluetooth
Wireless
QWERTY UK
671 g
Carrying Case
Material
Polycarbonate
Adjustable stand, sleep/wake function, Apple pencil holder, drop protection up to 2 m, multi-pairing
USB-C charging cable
Rechargeable
Run Time (Up To)
1 years
Brand: Zagg
