Zagg mophie AirPods Max Charging Stand with USB-C (AirPods Max/Ai
Quicklinx: JCVNWS00 Mfr#: 401316655
Hurry, only 2 left in stock!
£94.48 ex VAT
£113.37 inc VAT
The AirPods Max Charging Stand is the perfect home for your headphones. This sleek, wireless charging stand delivers power to both your headphones and AirPods earbuds. And it provides a dedicated storage spot, so you always know where they are. To charge your AirPods Max, insert the included USB-C dongle and then place them in the silicone cups on the stand. To charge your AirPods/AirPods Pro earbuds, simply place them on the wireless charging surface on the stand.
The indicator light lets you know when charging has begun. The AirPods Max Charging Stand has a bold, minimalist design that looks good in your space. Its quality shows in the craftsmanship of its aluminum base, soft-touch silicone resting cups, and silicone USB-C cable.
Charge Two Devices at Once: Charge AirPods Max headphones, AirPods/AirPods Pro earbuds or another Qi-enabled device at the same time.
Magnetic USB-C Dongle: Plug the included USB-C dongle into the AirPods Max and then set them on the stand where the dongle aligns perfectly with the charging pins.
Built-in Sleep Mode: The AirPods Max automatically enters sleep mode when placed on the charging stand.
Integrated Wireless Charging Pad: Charge your AirPods/AirPods Pro earbuds or other Qi-enabled device at the same time.
Premium Materials: The craftsmanship is evident in its aluminum base, soft-touch silicone resting cups, and silicone USB-C cable.
Anti-Scratch Protection: Silicone cups on the charging stand protect your AirPods Max from scratches.
Charging Indicator: The charging indicator light illuminates when charging has begun.
2-Year Warranty: We warrant this product against defects in materials and workmanship under normal use for a period of two years, as applicable, from the date of retail purchase by the original end-user consumer.
Brand: Zagg
