Tablet Keyboard & Case Enjoy high-end features and design at an affordable price.The new Messenger Folio 2 packs a punch with premium features like the space-efficient standing design and highlighted function keys. Its durable, protective case has a magnetic closure and holder for your Apple Pencil.Your iPad locks into a slot on the keyboard and fits neatly into the top of the case, making it easy to use in tight spaces, like an airplane tray.The magnetic closure provides additional protection, holding the case securely closed until you're ready to use it again.Spacious laptop-style keys provide a comfortable typing experience.The row of function keys at the top of the keyboard increase your speed and efficiency.Messenger Folio 2 has Type-C charging, the latest, most convenient way to charge. Compatible with 10.2-in. Apple iPad (7th & 8th gen) and 10.5-in. iPad Air (3rd gen). Messenger Folio 2 has a 1-year battery life.* The sleep/wake function helps preserve battery life when the keyboard is not in use.*Based on regular use of one hour per day.
Space efficient, standing design
The Messenger Folio 2 case holds your device securely upright, so you don't need extra surface space to accommodate a kickstand. Your tablet locks into a slot on the keyboard and fits neatly into the top of the case, making it easy to use in tight spaces, like an airplane tray. -
Laptop-style keys
No more cramped typing and misspelled words. Spacious laptop-style keys with clean precise keystrokes make typing fast and easy. -
Highlighted function keys
The row of highlighted function keys at the top of the keyboard increases your speed and efficiency. Shortcut keys like Apps Running, Keyboard Hide/Show, Search, Pairing, Play, Next Play, Volume Control and more means you don't have to hunt and scroll for options. -
On-the-go efficiency
Messenger Folio 2 is easy to use when you are on-the-go with instant pairing and type-C charging. The magnetic closure holds the case securely closed while it's in your bag. The Messenger Folio 2 case has a polished look and comfortable feel. -
Long-lasting battery
Type for up to a year before recharging the battery. The keyboard automatically turns off when folded backwards against the tablet. The sleep/wake function helps preserve battery life when keyboard is not in use.
- ZAGG Messenger Folio 2 - keyboard and folio case - QWERTY - UK - charcoal Input Device
- Keyboard and folio case
- Interface
- Bluetooth
- Localization and Layout
- QWERTY UK
- Hot Keys Function
- Power, search, mute, browser, play/pause, previous track, next track, home screen, battery check button, volume -, volume +
- Charcoal keyboard, charcoal case
- 26.67 cm x 19.685 cm x 2.082 cm
- 537 g
- 2-year warranty
- Designed For
- Apple 10.2-inch iPad (7th generation, 8th generation); 10.5-inch iPad Air (3rd generation)
- Interface
- Bluetooth
- Hot Keys Function
- QWERTY UK
- 26.67 cm
- 19.685 cm
- 2.082 cm
- 537 g
Carrying Case
- Charcoal
- Magnetic closure, transformable into a stand for typing or viewing video, integrated kickstand, Apple pencil holder, laptop-style keys
- Charcoal
- Included Accessories
- Charging cable
- Rechargeable
- Shipping Width
- 20.815 cm
- Shipping Depth
- 29.1 cm
- Shipping Height
- 3.04 cm
- Limited warranty - 2 years
- Designed For
- Apple 10.2-inch iPad (7th generation, 8th generation) , Apple 10.5-inch iPad Air (3rd generation)
