Zagg Crystal Palace Snap Case for iPhone 17
Quicklinx: JCTMWS00 Mfr#: 702318856
10 In Stock
£16.93 ex VAT
£20.31 inc VAT
Your new iPhone is ultra-modern, clean, and show-worthy. It’s more than a device—it says a lot about you. So protect it without eclipsing its beauty. The Crystal Palace Snap elegantly stands up to the task, balancing clarity with exceptional strength. This case covers every detail so you can focus on enjoying the phone you love.
It starts with an incredible 13 feet of drop protection engineered into the case’s structure, incorporating ultra-resilient graphene that reinforces without adding bulk. The Crystal Palace Snap’s anti-yellowing technology and anti-scratch finish keep your case (and phone) looking pristine, and of course, it’s built MagSafe compatible and works flawlessly with wireless chargers. It’s the perfect sidekick—fitting in seamlessly while handling the heavy lifting.
Crystal Clarity: Enjoy pristine transparency that lasts, thanks to ClearGuard™ anti-yellowing technology stays beautifully clear.
Drop Resistant up to 13ft/4m: Your case may be clear as crystal but it’s strong like a diamond—protecting your phone from drops as high as 13 feet up.
Strengthened with Graphene: Graphene is harder than a diamond, yet more elastic than rubber, and up to 200x stronger than steel.
Sleek, Minimalist Design: Classic, seamless, and transparent, the Crystal Palace Snap shows off your phone’s natural beauty without standing in the way.
Anti-Scratch Finish: The anti-scratch coating helps the case maintain its beauty over time.
Secure Grip: Textured edges provide a no-slip grip whether you’re holding your phone or fishing it out of your pocket.
Compatible with Magnetic Accessories: Crystal Palace Snap is MagSafe-compatible and works with wireless chargers and magnetic accessories.
Up to 61% Recycled Content: Don’t sweat your environmental footprint—Crystal Palace Snap is made with up to 61% recycled materials.
Limited Lifetime Warranty: If your case breaks, we’ll replace it for the life of your device.
Brand: Zagg
