The transparent Crystal Palace Lite Snap case has a seamless design that shows off the sleek lines of your phone. Anti-yellowing technology helps maintain the case's clarity. Crystal Palace Lite Snap is 40% lighter than previous designs, so it fits comfortably in your hand or your bag. Protect your phone from drops up to 6.6 feet while showing it off with the Crystal Palace Lite Snap case.
- Zagg Crystal Palace Lite Snap - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- 90.7 g
- Clear
- Product Recycled Content
- 53 % - made of post-consumer recycled content
- Limited lifetime warranty
- Designed For
- Apple iPhone 16
- 90.7 g
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Yellowing protection, drop protection, heat dissipating
- Cover Type
- Back cover
- Molded design, wrapped edges, wireless charging support, strengthened with graphene
- MagSafe Compatibility
- MIL-STD 810G 516
- Max Height of Drop Protection
- 2 m
- Limited warranty - lifetime
- Designed For
- Apple iPhone 16
