Yealink T31G SIP PHONE
Quicklinx: J0Y6WS00 Mfr#: SIP-T31G
£41.09 ex VAT
£49.30 inc VAT
As a very fashionable and friendly entry-level Gigabit IP phone, Yealink SIP-T31G has an extra-large 132x64-pixel graphical LCD with backlight that brings clear visual experience for users. The T31G offers support for two VoIP accounts and includes local 5-way conferencing to maximize productivity. Working with the adjustable multi-angle stand, the T31G IP phone ensures you to work in different situation. Meanwhile, the T31G features built-in Power over Ethernet (PoE) and superb high definition (HD) sound quality. Easy-to-use and powerful features together with reasonable price deliver excellent voice communications solution.
  • Stronger performance, more possibilities
    Equipped with powerful chip, the T3 series owns a stronger computing ability and more upgraded functions, which ensures a higher productivity and smoother office experience. Due to great performance, T3 series is capable to extend more services for different business demands.
  • Superior HD Audio, better communication
    The Yealink T3 series provides distraction-free communications with industry leading Smart Noise Filtering Technology, which delivers excellent sound quality without extraneous noises and allows fluent conversations.
  • Classic design, practical details
    Designed by Yealink original team, T3 series inherits the design concept of Yealink IP phone family. The advanced design including modern appearances and ergonomic details enables easier and friendly operation experience to users.
  • All in one platform, convenient management
    Proven reliability and integrations for Yealink Device Management Platform, installed the unified firmware, T3 series is simple to deploy and manage, which allows a significant reduction in the operation and maintenance cost.
Yealink SIP-T31G - VoIP phone - 5-way call capability
VoIP phone
Main Features
Multiple VoIP protocol support, integrated Ethernet switch
VoIP Protocols
SIP, SIP v2, SRTP
Voice Codecs
G.722, G.723.1, G.729ab, G.726, iLBC, G.711A/µ
Lines Supported
2 lines
Speakerphone
Call Services
Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold, Message Waiting Capability
Display
LCD display - monochrome - Yes
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX
Body Colour
Classic gray
VoIP phone
Body Colour
Classic gray
Phone Features
Call Services
Dialer Location
Base
Conference Call Capability
5-way
Speakerphone
Volume Control
Indicators
Voice message waiting indicator
Additional Functions
Call recording, Intercom
IP Telephony
Main Features
VoIP
VoIP Protocols
SIP, SIP v2, SRTP
Voice Codecs
Lines Supported
2 lines
Quality of Service
IEEE 802.1Q (VLAN), IEEE 802.1p
IP Address Assignment
DHCP, static, PPPoE
Security
TLS
Power Over Ethernet (PoE) Support
Network Protocols
IP, TFTP, HTTP, DNS, SNMP, HTTPS, Link Layer Discovery Protocol (LLDP), SRTP, STUN
Network Ports Qty
Voice Features
Comfort noise generation (CNG), voice activity detection (VAD), HD Voice, acoustic echo cancellation (AEC), packet loss concealment (PLC), adaptive jitter buffer (AJB), automatic gain control (AGC)
Network Features
Network Address Translation (NAT), Lightweight Directory Access Protocol (LDAP)
Phone Memory
Phone Directory Capacity
1000 names & numbers
Display
Display Location
Base
Diagonal Size
2.3"
Display Resolution
132 x 64 pixels
Backlit
Headset jack / RJ-9 , Handset jack / RJ-9
Placing / Mounting
Wall-mountable, table-top
Ethernet cable
Stand
Dimensions & Weight (Base)
18.8 cm
18.9 cm
16.2 cm
Brand: Yealink
