Yamaha YVC-1000 Microphone + Speaker System
Quicklinx: BNV8WS00 Mfr#: 10-YVC1000-UK
The YVC-1000 features separate microphone and speaker units that smoothly integrate audio and video for natural, comfortable remote communication. The high performance, full range speaker unit can be placed close to the display so that audio and video from the remote location blend naturally, while adaptive echo canceler and other Yamaha sound processing technologies facilitate stress-free conversation.
  • Fast, easy connection to PCs, smartphones, tablets, and dedicated conferencing systems
    Connect to the YVC-1000 via USB, Bluetooth, or the audio terminals of a conferencing system for high-quality audio in your conferences and meetings. This range of connection options allows you to quickly adapt to a variety of communications environments, as well as situations where conferencing might otherwise be difficult due to the lack of a landline, or Internet connectivity issues.
  • Smooth Bluetooth connection
    Connect simply and easily by placing an NFC-compatible smartphone or tablet over the NFC logo on the top of the control unit while the Bluetooth button is blinking.
  • Excellent scalability
    In its standard configuration the YVC-1000 is ideal for small and medium-size meetings. For conferencing on a large scale, external speakers and up to four additional microphones can be added to cover a wider area and accommodate more conference participants.
  • User-friendly design
    The YVC-1000 automatically optimizes its acoustic settings by learning about the acoustic environment of a room as it operates. When time requirements mean that speed is an issue, simply pressing the tuning fork button activates the automatic audio tuning function, immediately optimizing the acoustic settings for your current environment. If any acoustic problems are detected, the tuning fork button lights up orange to warn the user. Details on acoustic problems can be accessed through the audio guidance function, which also provides announcements for other operations, such as when Bluetooth connections have been established.
  • Communicate with various sources simultaneously
    The audio mixing function mixes multiple voice input sources connected to each interface (USB, Bluetooth, and audio input/output) allowing simultaneous communication over different lines. For example, while connected to a web conference via USB, you can also include more participants via smartphone using a Bluetooth connection by using the audio mixing function to combine the audio sources.
  • Great sound processing technologies
    The YVC-1000 incorporates many high-quality sound technologies that Yamaha has developed over the years, including a unique Human Voice Activity Detection (HVAD) capability used to detect human voices. HVAD is an important element of several different sound processing features that require fast and efficient sorting of noise and human voices in order to make speaking and listening a more relaxing, stress-free experience during remote conferencing.
Yamaha YVC-1000 - speakerphone
Speakerphone - Bluetooth - wireless - NFC
United Kingdom
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 2.1 EDR
Sound Output Mode
Mono
Audio Specifications
Frequency Response 100 - 20000 Hz - Sensitivity 95 dB
Max Operating Distance
10 m
United Kingdom
Audio Output
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 2.1 EDR
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Low Complexity Subband Coding (SBC)
Sound Output Mode
Mono
Frequency Response
100 - 20000 Hz
Sensitivity
95 dB
Microphone
Wired
Frequency Response
100 - 20000 Hz
Audio Input Details
Uni-directional - 100 - 20000 Hz
Wireless Link
Transmission Range
10 m
Connector Type
USB (4 PIN USB Type B) , Audio line-in (RCA x 2) , Audio line-out (RCA x 2) , Speakers output (RCA x 2) , Microphone
Control unit
Cable Details
USB cable - 5 m , Microphone cable - 5 m
AC 100 V (50/60 Hz)
20 Watt
