This 7.2-channel network AV receiver features Dolby Atmos and DTS: X object based surround sound decoding along with 4K Ultra HD video technologies, built-in Bluetooth and Wi-Fi to conveniently access music wirelessly from a mobile device, advanced speaker configurations and Zone B audio to provide added system versatility.
DTS: X and Dolby Atmos
Experience dimension. Enter a world of sound with Dolby Atmos and DTS: X. These sound technologies transport you from an ordinary moment into an extraordinary experience with captivating, multidimensional sound that fills your room with amazing richness and depth. These sound technologies allow for music, people and objects to come alive in breathtaking detail and flow in precise choreography all around you, making you feel like you are right in the middle of the story. -
Dolby Atmos speaker patterns
Sound fields galore. Multiple placement patterns are available for presence speakers that support Dolby Atmos, creating a sound field that's ideal for your setup. Any layout can be appropriately reproduced, including the three-dimensional space of CINEMA DSP as well as Dolby Atmos. -
All your content
Everything you can imagine. MusicCast allows you to access your digital music library, streaming music services and Internet radio, as well as Bluetooth sources, your TV sound and external sources attached to your AV receiver, such as a Blu-ray disc or CD player. -
Bluetooth
Play your favorite streaming service. This AV receiver is equipped with Bluetooth functionality to let you enjoy easy wireless music playback from smartphones and other devices. The Compressed Music Enhancer, a digital sound processing technology from Yamaha, is now optimized for Bluetooth audio transmissions to ensure that your music will have vivid, lively sound quality during wireless playback. -
HDMI CEC
More controllability. Another benefit of HDMI is the availability of CEC functionality. When the unit is connected to a CEC compatible TV, it will turn on and off together with the TV and you can use the TV remote to control the volume. CEC also provides advanced functionality with other components. For example, you can use the AV receiver remote to control player functions like skip and stop. -
4K, HDR and BT.2020
Darker blacks, whiter whites and more vivid colors. This unit supports the latest HDMI standards thanks to the transmission of 4K video at 60 frames per second (pass-through only). Fully enjoy the high-definition video quality of 4K without degradation along with HDCP 2.2, a standard for 4K video transmission. It also supports the wider color gamut of BT.2020 pass-through.
- Yamaha RX-V581 - AV network receiver - 7.2 channel
- Product Type
- Enclosure Colour
- Black
- Audio Channels
- Surround Sound
- Decoders
- DTS Neo:6, DTS-ES Matrix 6.1, DTS-ES Discrete 6.1, DTS 96/24, Dolby Digital, DTS decoder, Dolby Pro Logic IIx, DTS Express, Dolby Digital Plus, SBC decoder, DSD decoder, Dolby TrueHD, DTS-HD Master Audio, DTS-HD High Resolution, Dolby Digital EX, Dolby Atmos, DTS:X
- Surround Sound Effects
- Virtual CINEMA DSP, SILENT CINEMA DSP, CINEMA DSP 3D, Virtual Presence Speaker, Virtual CINEMA FRONT, Virtual Surround Back Speaker
- Sound Effects
- Extra Bass
- Surround System Class
- 7.2 channel
- Source
- Network, USB-host, Bluetooth
- Audio Formats
- WAV, WMA, AAC, AIFF, PCM, MP3, FLAC, DSD, ALAC
- Radio System
- AM/FM - 40 preset stations
- Streaming Services
- Pandora, Spotify, JUKE
- Ethernet, Fast Ethernet, Bluetooth, Wi-Fi
- 43.5 cm x 32.7 cm x 16.1 cm
- 8.1 kg
- 2-year warranty
- Product Type
- Enclosure Colour
- Black
Audio System
- Audio Channels
- Surround Sound
- Decoders
- 3D Technology
- Functions
- Digital player, AV network receiver, internet radio
- Source
- Audio Formats
- Audio D/A Converter
- 24bit / 192kHz
- Sound Effects
- Extra Bass
- Equaliser
- Digital Sound Processor (DSP)
- DSP Preset Qty
- 17
- 3D Pass-Through
- 7.2 channel
- Amplifier Output details
- 115 Watt - 6 Ohm - at 1 kHz - THD 0.9% - 1 channels , 80 Watt - 6 Ohm - 20 - 20000 Hz - THD 0.09% - 2 channels
- Built-in clock
- Sleep timer
- Bass Control
- Treble Control
- On-screen display, Bi-Amplifying, Yamaha Parametric Room Acoustic Optimizer (YPAO), dual-zone capability, compressed music enhancer, Bluetooth Audio Streaming, Audio Return Channel (ARC), Apple AirPlay support, iPod/iPhone ready, smartphone remote controlled, Wi-Fi Direct, x.v.Color, Deep Colour, MusicCast system
Signal Processing Features
- HDMI Pass-Through
- Up to 4K
Radio System
- AM/FM - digital radio tuner
- Preset Station Qty
- Supported RDS Functions
- CT, PTY, PS, RT
- Auto Preset Memory
Network & Internet Multimedia
- DLNA
- Connectors
- Headphones (phone stereo 6.3 mm) - front , Audio line-in (mini-phone stereo 3.5 mm) - front , USB (4 PIN USB Type A) - front , 4 x HDMI input (19 pin HDMI Type A) - rear , HDMI output (19 pin HDMI Type A) - rear , 4 x composite video input (RCA) - rear , Composite video output (RCA) - rear , 3 x audio line-in (RCA x 2) - rear , Digital audio input (optical) (TOS Link) - rear , 2 x digital audio input (coaxial) (RCA) - rear , 2 x subwoofer output (RCA) - rear , LAN (RJ-45) , 7 x speakers output (banana/spade x 2) - rear
- Included Accessories
- AM antenna, remote control, FM antenna, 2 AAA batteries, auto calibration microphone
- 260 Watt
- Power Consumption Stand by
- 0.1 Watt
- Limited warranty - parts and labour - 2 years
- 43.5 cm
- 32.7 cm
- 16.1 cm
- 8.1 kg
