The stylish, flexible design allows wall mounting or placement on a TV stand.
The YAS-105 delivers a total of 120 W (60 W + 30 W + 30 W) of very powerful and dynamic sound from its slim and stylish cabinet. In addition to the left and right speakers, it has two built-in subwoofers and two balance dome tweeters. This contributes to clear separation between mid and high range tones. For music, the mid-high sounds become more transparent and for movies, the sound is much more dynamic.
AIR SURROUND XTREME is Yamaha's unique virtual surround technology, delivering full, rich sound with a cohesive sense of surround placement. Enjoy immersive surround sound with all kinds of audio sources, from movies to sports and music.
Versatile style
The stylish, flexible design allows wall mounting or placement on a TV stand. -
Powerful sound with excellent full-range quality
The YAS-105 delivers a total of 120 W (60 W + 30 W + 30 W) of very powerful and dynamic sound from its slim and stylish cabinet. In addition to the left and right speakers, it has two built-in subwoofers and two balance dome tweeters. This contributes to clear separation between mid and high range tones. For music, the mid-high sounds become more transparent and for movies, the sound is much more dynamic. -
AIR SURROUND XTREME provides spacious home theater experience
AIR SURROUND XTREME is Yamaha's unique virtual surround technology, delivering full, rich sound with a cohesive sense of surround placement. Enjoy immersive surround sound with all kinds of audio sources, from movies to sports and music. -
Dual built-in subwoofers powerfully reproduce bass sounds
The YAS-105 employs dual subwoofers inside the cabinet that point upward. Even without a standalone subwoofer, you can enjoy powerful bass sound. Since the sound is output upward, the bass response is very quick and punchy. For music reproduction, the bass notes and rhythm is very accurate. -
Bass reflex port contributes to deeper, richer bass
The YAS-105 employs a bass reflex port that has adequate length to provide outstanding bass response together with the large volume cabinet. The duct outlet is shaped like a trumpet bell, which reduces air output noise for better sound clarity. -
Slim body for a beautifully stylish installation
Whether on a flat surface or on a wall, the YAS-105 has the right style for perfect installation. With a height of only 53 mm (2-1/8"), it won't block the screen so you can set it right in front of the TV, and it will also look attractive mounted on a wall. It connects to your TV via a single cable, so setup is quick and easy. -
Bluetooth wireless music streaming from your smartphone or tablet
Enjoy the sound of music or movies from your smartphone or tablet wirelessly. While watching the screen, it's easy to perform select, play and stop operations, as you enjoy sound backed by the power of the YAS-105. There is also a Bluetooth standby mode, so by linking to Bluetooth on/off via the terminal, you get the convenience of the YAS-105 turning on and off automatically. -
Power saving design
The YAS-105 features low power consumption of only 0.4 W. -
Versatile connectivity
There are four input terminals: optical, coaxial, stereo mini and Bluetooth. There is also a subwoofer output terminal. -
Clear Voice makes dialog and narrations easy to hear
Clear Voice raises the level of dialog and narrations while maintaining overall sound quality. Movies and TV shows, sports commentary and news broadcasts are more clearly audible.
- Yamaha YAS-105 - sound bar - wireless
- Product Type
- Sound bar - 2.1-channel
- Speaker Type
- Active
- Continuous Power
- 120 Watt
- Frequency Response
- 55 - 23000 Hz
- Amplifier
- Integrated
- Bluetooth
- Audio Formats
- AAC, PCM
- Speaker Details
- Sound bar - stereo x 2 - 30 Watt - at 1 kHz - 10% THD - 6 Ohm - 2-way - active , Sound bar - subwoofer - 60 Watt - at 100 Hz - 10% THD - 3 Ohm - active
- Silver
- Built-in Decoders
- Dolby Pro Logic II, Dolby Digital, SBC decoder, Dolby Audio
- Sound Effects
- Air Surround Xtreme, Clear Voice
- 89 cm x 13.1 cm x 5.3 cm
- 4 kg
- Product Type
- Enclosure Colour
- Silver
Speaker System
- Speaker Type
- Active
- Continuous Power
- 120 Watt
- 55 - 23000 Hz
- Amplifier
- Integrated
- Sound Effects
- Bluetooth 2.1 EDR
- Bluetooth Profiles
- Serial Port Profile (SPP), Advanced Audio Distribution Profile (A2DP)
- Transmission Range
- 10 m
- Built-in Decoders
- Audio Formats
- AAC, PCM
- Controls
- Input selector, mute, power on/off, volume
Speaker System Details
- Speaker Details
- Sound bar - stereo x 2 - 30 Watt - at 1 kHz CFR - 10% THD - 6 Ohm - 2-way - active , Sound bar - subwoofer - 60 Watt - at 100 Hz CFR - 10% THD - 3 Ohm - active
- Driver Details
- Sound bar: 2 x mid/woofer driver - 2-1/8" , Sound bar: 2 x tweeter driver - 3/4" , Sound bar: 2 x subwoofer driver - 3"
- Connector Type
- SPDIF input (TOS Link) , SPDIF input (RCA) , Audio line-in (mini-phone stereo 3.5 mm) , Subwoofer output (RCA)
- Included Accessories
- Digital audio cable (optical), remote control, 2 AAA batteries, spacer, wall template
- Power Source
- AC power adapter
- 22 Watt
- 89 cm
- 13.1 cm
- 5.3 cm
- 4 kg
