Yale Sync Smart Home Alarm - Family Kit
Quicklinx: G5P7WS00 Mfr#: IA-320
Type: Home security system
Compatible With: Alexa
20 In Stock
£215.84 ex VAT
£259.00 inc VAT
The Sync Smart Home Alarm puts you firmly in control, giving you peace of mind, assured that your home is secure and protected. Check from anywhere in the world and receive alerts and notifications when your alarm is triggered, so you'll always be in the know - with no monitoring fees.
The Sync Smart Home Alarm 6 Piece Kit is completely wire-free, eliminating the need for cables running through your property. This means that you have the flexibility to take your home alarm system with you, if ever you move. It is also expandable, so you can design the perfect security solution to suit your home. You can add extra door and window contacts, PIR sensors, smoke alarms, smart plugs, keypads, water leak sensors and if you have a furry friend, you can opt for pet friendly PIR motion detectors. You can add up to 40 accessories and connect them seamlessly to your Sync Smart Home Alarm 6 Piece Kit.
Forget about long-term contracts, when you purchase the Sync Smart Home Alarm 6 Piece Kit you aren’t tied into any monthly rolling or monitoring fees.
What's in the box? The Yale Sync Smart Home Alarm 6 Piece Kit comes with:
1x Smart Hub
1x Yellow Siren
2x Motion Detector
1 x Door/Window Contact Sensor
1x Keypad
  • Full in-app control
    The Yale Smart Living Alarm App gives you full control of your Sync Smart Home Alarm 6-Piece Kit and connected devices. Check-in from anywhere in the world, receive alerts and real-time notifications in the event that your alarm is triggered. You are also able to control and check the status of your smart alarm system through your smartwatch.
  • The perfect pairing
    Seamlessly integrate your Yale Sync Smart Home Alarm and Yale Smart Lock with the Yale Sync Module, creating the perfect pairing between the two systems. You can automatically disarm your alarm when opening the lock (although your alarm cannot be armed by locking).
  • Secured by Design
    Secured by Design, the official police security initiative that works to improve security of buildings and their immediate surroundings have accredited the Sync Smart Home Alarm 6-Piece Kit under the Police Preferred Specification scheme.
Yale Smart Living Sync Smart Home Alarm - Family Kit - home security system
Power Source
Battery, power adapter
Internet of Things (IoT) Platform
Hue
Intelligent Assistant
Alexa
Package Content
Door and window sensor, keypad, siren, 2 x motion sensors, system hub
Max Supported Devices
40
Wireless, wired
Frequency Band
868 MHz
Supported Host Device OS
iOS, Android
26.5 cm x 26.5 cm x 19.8 cm
Power Source
Package Content
40
Wireless, wired - Ethernet
Max Range Indoors
200 m
Frequency Band
868 MHz
Android 4.2 (Jelly Bean) or later, iOS 9 or later
Interfaces Details
LAN
Status notification, radio jamming detection
Platform
Hue
Alexa
Motion Sensor
Detection Mode
Passive infrared (PIR)
Detection Range
12 m
Detection Angle
110 degree(s)
Warranty
26.5 cm
26.5 cm
19.8 cm
2.59 kg
Brand: Yale
