Yale Smart Door Lock Keyless Connected No Module
Quicklinx: D2GHWS00 Mfr#: YD-01-CON-NOMOD-CH
Type: Smart Lock
Compatible With: [N/A]
Hurry, only 3 left in stock!
£82.50 ex VAT
£99.00 inc VAT
The Yale keyless connected smart lock gives you freedom to secure your home without the need for a key. Simple to use, you now have complete control on how you unlock your door.
Convenience
There's no need to worry if your children arrive home early, or if you're stuck at work with friends on your doorstep. You control who and when people have access to your home. For example, you can set a PIN code that works for 24 hours for a family member or your cleaning person.
Simple to use
You choose how you want to open your door. PIN code, key card, key tag, remote fob and even from your smartphone when connected to a smart home system. It is also easy to add and remove users if you need to.
Security as standard
Feeling safe and secure is a must for any home owner. The smart lock has a tamper alarm and incorrect PIN code feature.
Always On
Don't worry if the electricity goes down as the smart lock is powered by 4 AA batteries. It will even warn you when the batteries are running low.
Complete your smart home system. The Keyless Connected smart lock can connect to leading smart home systems when the appropriate module is fitted. It also connects to the Yale Smartphone Alarm and CCTV systems when you use the Yale module.
  • Convenience
    There's no need to worry, if your children arrive home early, or if you're stuck at work with friends on your doorstep. You control who and when people have access to your home. For example, you can set a PIN code, that works for 24 hours for a family member or your cleaning person.
  • Simple to use
    You choose how you want to open your door. PIN code, key card, key tag, remote fob and even from your smartphone, when connected to a smart home system. It is also easy to add and remove users, if you need to.
  • Security as standard
  • Always on
    Don't worry, if the electricity goes down as the smart lock is powered by batteries. It will even warn you, when the batteries are running low.
  • Connectivity
    Complete your smart home system. The keyless connected smart lock can connect to leading smart home systems, when the appropriate module is fitted. It also connects to the smartphone alarm and CCTV systems, when you use the module.
Yale Keyless Connected - door lock
Door lock - smart lock - electronic, key-card - touch keypad
Code Length
4-10 digits
Door lock - electronic, key-card - smart lock - touch keypad
Code Length
4-10 digits
Package Content
Mounting hardware, key tag, key card
Low battery indicator, nightlatch, temporary visitor code
4 x AA type
IP55
2 years
64 mm
51 mm
153 mm
-15 °C
55 °C
Type: Smart Lock
Brand: Yale
