Yale Keyless Connected No Module - Satin Nickel
Quicklinx: G5RXWS00 Mfr#: YD-01-CON-NOMOD-SN
Type: Smart Lock
Compatible With: [N/A]
Hurry, only 1 left in stock!
£83.33 ex VAT
£99.99 inc VAT
The Yale Keyless Connected smart door lock gives you freedom to secure your home without the need for a key. Simple to use, you now have complete control on how you unlock your door.
  • Keyless
    Say goodbye to your keys.
  • One touch control
    Unlock your door with one simple tap.
  • Up to 20 users
    Use a mix of up to 20 PIN codes, key tags and key cards.
  • Enhanced encrypted security
    Enhanced security to prevent unauthorized access.
  • Easy to fit
    Get your Smart Door Lock up and running in no time.
  • Tamper alarm
    Protected by an 80db internal alarm.
  • Battery powered
    No wires, no hassle. Easy to replace.
  • Time controlled user codes
    24-hour PIN code for visitors.
Yale Keyless Connected - door lock - satin nickel
Door lock - smart lock - electronic, key-card - touch keypad
Code Length
4-10 digits
- RFID
Satin nickel
Door lock - electronic, key-card - smart lock - touch keypad
Code Length
4-10 digits
Package Content
Mounting hardware, key tag, key card
Low battery indicator, nightlatch, temporary visitor code (24 hours), remote access, built-in sound alarm (80 dB), programmable up to 20 users
4 x AA type
Satin nickel
IP55
Type: Smart Lock
Brand: Yale
