The Yale Keyless Connected smart door lock gives you freedom to secure your home without the need for a key. Simple to use, you now have complete control on how you unlock your door.
Keyless
Say goodbye to your keys. -
One touch control
Unlock your door with one simple tap. -
Up to 20 users
Use a mix of up to 20 PIN codes, key tags and key cards. -
Enhanced encrypted security
Enhanced security to prevent unauthorized access. -
Easy to fit
Get your Smart Door Lock up and running in no time. -
Tamper alarm
Protected by an 80db internal alarm. -
Battery powered
No wires, no hassle. Easy to replace. -
Time controlled user codes
24-hour PIN code for visitors.
- Yale Keyless Connected - door lock - satin nickel
- Product Type
- Door lock - smart lock - electronic, key-card - touch keypad
- Code Length
- 4-10 digits
- Connectivity
- - RFID
- Satin nickel
- Product Type
- Door lock - electronic, key-card - smart lock - touch keypad
- Code Length
- 4-10 digits
- Package Content
- Mounting hardware, key tag, key card
- Low battery indicator, nightlatch, temporary visitor code (24 hours), remote access, built-in sound alarm (80 dB), programmable up to 20 users
- 4 x AA type
- Satin nickel
- IP55
