Open the door to your world with the Conexis L1 Smart Door Lock. The Smart Door Lock that puts you fully in control giving you the freedom to secure your home without the need for a key.
Control via smartphone
Configure, Control and unlock your Smart Door Lock from your smartphone via our secure Bluetooth App. -
Keyless
Say goodbye to keys, Open your Smart Door lock via your smartphone, Key Card or Key Tag. -
Simple to fit
Engineered for easy installation. Fits all 92mm centered multi-point locks. -
Security as standard
Built in tamper alarm, PAS24 accredited. -
Battery operated
Powered by 4 AA batteries and a warning when they're running low. -
Battery backup
A 9v battery connection port can be used to power the Smart door lock in the event of flat batteries. -
Secure push & turn thumbturn
Engineered to give additional convenience and security to your door.
