Y-cam Knight IP Camera External Housing
Quicklinx: 53DNWS00 Mfr#: YCEX01
The Y-cam Shell is an external housing enabling any of Y-cam's indoor Y-cam models to be mounted outside. It is built from carefully specified materials to minimize signal attenuation, making sure that your Wi-Fi signal retains its strength, while always protecting your camera from the elements.
The mounting bracket is universal - allowing the camera to be orientated in any desired direction and is semi-cable managed allowing the power and, if necessary, the Ethernet/network cable to be routed to the camera.
Manufacturer
Y-cam Solutions
Product Line
Y-cam Knight
