XYZprinting produces high quality ABS filaments that offer longer lifespan, better impact resistance, and finer appearance that makes it suitable for external components or model parts. Additionally, you can easily use common modeling tools to decorate, assemble or connect different parts to create your perfect. Easy to install filament cartridges available in many vivid colors. XYZprinting filament cartridges are designed and tested to ensure that there is no distortion in color or form ensuring your designs come out perfect every time.
- XYZprinting - purple - ABS filament
- Product Type
- ABS filament
- Filament Diameter
- 1.75 mm
- 600 g
- Printing Technology
- FDM
- Printing Colour
- Purple
- Compatible with
- Da Vinci 1.0
Consumable
- Consumable Type
- ABS filament
- Filament Diameter
- 1.75 mm
- 600 g
- FDM
- Purple
- Nozzle Temperature
- 210 °C
- Glass Transition Temperature
- 90 °C
- Included Qty
- 1-pack
- Compatible with
- XYZprinting da Vinci 1.0
