XYZprinting produces high quality, long lasting, ABS filaments that offer better impact resistance making it suitable for external components or model parts. Additionally, you can easily use common modeling tools to decorate, assemble or connect different parts to create your next big project.
Put to the test
XYZprintings filaments have been extensively tested on da Vinci 3D printers and XYZware for high-performance 3D printing. -
Color & form
XYZprinting's vividly colored filament is engineered and tested to make sure that there is no distortion in the color and form of the filament. -
Easy to replace filament
The XYZprinting filament has been designed to be easy to install and replace. The da Vinci will also notify you when the filament is running low so you don't run out.
- XYZprinting - neon yellow - ABS filament cartridge
- Product Type
- Filament Diameter
- 1.75 mm
- 600 g
- Printing Technology
- FDM
- Printing Colour
- Neon yellow
- Compatible with
- Da Vinci 1.0, 1.0 Aio
- Shipping Weight
- 1.25 kg
Consumable
- Consumable Type
- Filament Diameter
- 1.75 mm
- 600 g
- FDM
- Neon yellow
- Nozzle Temperature
- 210 °C
- Glass Transition Temperature
- 70 °C
- Included Qty
- 1-pack
- Compatible with
- XYZprinting da Vinci 1.0, 1.0 Aio
