An outstanding performance air cooler, Prime SD1484 creates most efficient heat conduction and imbalance heat-pipe arrangement to provide dissipating surface and cooling performance. Prime SD1484 combines 140mm PWM fan, rubber fan clip, 4pcs F8 heat-pipe, supports multiple-platforms, and can be used on Socket 1366/ 1155/ 1156/ 775/ 2011 platform, and AM2/ AM3/ FM1 Socket.
- H.D.T (Heat-pipe Direct Touch) technology
- Patent Blade-Fin technology increases 20% of ventilation and drops 10% noise
- Patent Blade-Fin technology is good at the prevention of keeping dust away the fins edge
- Special fins (T: 0.5mm) style combination provides efficient air flow
- Unique & Patent Anti-vibration rubber fastens prevent vibration and absorb noise
- Dual fans installed option, 140mm or 120mm
- Equipped with multiple clips to support Intel LGA1366/1156/1155/775 and AMD AM3/AM2+/AM2
- 2 Years Manufacturers Warranty
Specifcations
- Product Name: Prime SD1484
- Product Number: CAC-SYHH4-U01
- Dimension: 145(W) x 60(D) x 159(H) mm
- Heat Sink: Base Material H.D.T. (Heat-pipes Direct Touch), Fin Material Aluminum Alloy
- Heat-pipe: SPEC F8mm, Q´ty 4pcs
- Fan: Dimension 140(W) x 140(H) x 25(D) mm, Voltage Rating 12V, Starting Voltage 9V, Speed 800~1200 R.P.M., Bearing Type Sleeve Bearing(with copper axle), Air Flow 90.3 CFM (Max.), Air Pressure 1.08 mmH2O (Max.), Life Expectance 40,000 hrs, Noise Level 18dBA (Max.), Connector 4 pin with PWM, Q´ty 2pcs
- Weight: 710g (Heat Sink Only)
- Thermal Resistance: 0.14 ?/W
- Warranty: 2 Years Manufactures Warranty
- XIGMATEK Prime SD1484 - processor cooler
- Product Type
- Processor cooler
- Compatibility
- LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket
- Heatsink Material
- Aluminium
- Fan Diameter
- 140 mm
- Fan Height
- 25 mm
- Fan Bearing
- Sleeve bearing
- Rotation Speed
- 800-1200 rpm
- Air Flow
- 90.3 cfm
- Noise Level
- 18 dBA
- Power Connector
- 3-pin plug, 4-pin fan connector
- Rated Voltage
- 12 V
- Heat-pipe Direct Touch (H.D.T.) Technology, 4 copper heatpipes (8 mm)
- 14.5 cm x 6 cm x 15.9 cm
- Product Type
- Processor cooler
- 14.5 cm
- 6 cm
- 15.9 cm
Heatsink & Fan
- Compatible With
- Processor Compatibility
- Core i3 , Core i5 , Core i7
- Heatsink Material
- Aluminium
- 0.14 °C/W
- Fan Diameter
- 140 mm
- Fan Height
- 25 mm
- Fan Bearing
- Sleeve bearing
- Rotation Speed
- 800-1200 rpm
- Air Flow
- 90.3 cfm
- Air Pressure
- 1.08 mm
- Noise Level
- 18 dBA
- Power Connector
- Rated Voltage
- 12 V
- Start Voltage
- 9 V
