XIGMATEK NRP-VC503 500W PSU
Quicklinx: 7BPZWS00 Mfr#: NRP-VC503
With EMI filter and safety certificates, Xigmatek launched the most suitable budget power supply for common users. Xigmatek VC series power supply means "Valued-Class" and offers the stable DC output and full electric protection with ideal cost/performance rate. VC series supports latest dual and quad cores CPU and mid-end graphic cards for home entertainment and gaming.
XIGMATEK NRP-VC503 - power supply - 500 Watt
Power supply - Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.2
Input Voltage
AC 115/230 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
500 Watt
Output Current
+12V1 - 15 A / 1 A , +12V2 - 16 A / 1 A , +3.3V - 22 A / 0.5 A , +5V - 16 A / 0.3 A , +5VSB - 2.5 A , -12V - 0.8 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 5 x 4 PIN internal power , 4 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector , 1 x 6 pin PCI Express power , 1 x power 8 pin +12V with detachable 4 pin section , 1 x 8 pin PCI Express power with detachable 2 pin section
Cooling System
120 mm fan
15 cm x 14 cm x 8.6 cm
ATX12V 2.2
PSU Form Factor
ATX
Input Voltage
AC 115/230 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
500 Watt
Output Current
MTBF
100,000 hours
Cooling System
120 mm fan
Over current protection, over voltage protection, overload protection, undervoltage protection, short-circuit protection, temperature controlled fan, non-modular
UL, TUV
5 °C
5 - 85% (non-condensing)
15 cm
14 cm
8.6 cm
