XIGMATEK Midgard Mid-Tower Case (USB/Audio/eSATA)
Quicklinx: 77R1WS00 Mfr#: CPC-T55DB-U01
"Midgard-W" - home of mankind and protected by Thor, God of thunder, and his hammer. Signalizing the strength of divines and mercy, but at the same time proprietary the hardware you built in. Combined design and features such as SECC and steel mesh are spotlighting your chassis when your system is built. Furthermore this chassis is supplied with 2 x 120mm pre-installed fans, but another 5 fans can be mounted in different areas for best possible airflow. Tool free design and a "gorgeous" outlook are only a few points why this chassis is a "must" not only for enthusiast but also for PC beginners.
Classic chassis exterior contains pure coating interior even with each screw. It is more elegant and fancy design than any other mid-tower chassis with ATX and Micro-ATX form factors.
XIGMATEK Midgard - tower - ATX
System cabinet
Tower
Pure black
I/O Connectors
2 x USB 2.0 , 1 x eSATA , 1 x audio line-out , 1 x microphone
Installed Fans Qty
2
Supported Motherboards
ATX, microATX
System Cabinet Features
Screwless drive bays, removable dust filter
Power supply (ATX12V / EPS12V)
20.6 cm x 51 cm x 47.7 cm
Tower
Max Mainboard Size
ATX
ATX, microATX
Internal Bays Qty
5
Front Accessible Bays Qty
5
Pure black
Fans
Front: 1 x 12 cm - (1 installed) , Rear: 1 x 12 cm - (1 installed) , Side: 2 x 14 cm - (0 installed) , Bottom: 1 x 14 cm - (0 installed) , Top: 2 x 14 cm - (0 installed)
Expansion Bays
4 (total) / 4 (free) x front accessible - 5.25" , 1 (total) / 1 (free) x front accessible - 5.25"/ 3.5" shared , 5 (total) / 5 (free) x internal - 3.5"
Expansion Slots
7 x Expansion Slot
2 x USB 2.0 , 1 x eSATA , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
Power supply
Specification Compliance
ATX12V / EPS12V
20.6 cm
51 cm
47.7 cm
