Achilles S1284C, a H.D.T. cooler, proves that it is possible to do concurrently both good-looking and performance. Its H.D.T. technology makes Achilles a remarkable performing and special fan design makes it to reach a silent level. With LED lights, transparent fan, anti-vibration rubber, Achilles S1284 offers not only friendly, reliable, easy to install, but also powerful performance for users.
- XIGMATEK Achilles S1284C - processor cooler
- Product Type
- Processor cooler
- Compatibility
- Socket 754, Socket 940, LGA775 Socket, Socket 939, Socket AM2
- Heatsink Material
- Aluminium
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Long Life Bearing
- Rotation Speed
- 800-1500 rpm
- Air Flow
- 61.4 cfm
- Noise Level
- 20.6 dBA
- Power Connector
- 4-pin fan connector
- Rated Voltage
- 12 V
- Heat pipe technology, white LED x4, Heat-pipe Touch Chip (HTC) technology, Pulse-width modulation (PWM) support
- 12 cm x 15.9 cm x 6 cm
- 0.66 kg
- Product Type
- Processor cooler
- 12 cm
- 15.9 cm
- 6 cm
- 0.66 kg
Heatsink & Fan
- Compatible With
- Processor Compatibility
- Core 2 Extreme - all speeds , Core 2 Duo - all speeds , Core 2 Quad - all speeds , Pentium D - all speeds , Celeron D - all speeds , Athlon 64 - all speeds , Athlon 64 FX - all speeds , Athlon 64 X2 - all speeds , Opteron - all speeds , Sempron - all speeds , Pentium Extreme Edition - all speeds
- Heatsink Material
- Aluminium
- Thermal Resistance
- 0.14 °C/W
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Long Life Bearing
- Rotation Speed
- 800-1500 rpm
- Air Flow
- 61.4 cfm
- Air Pressure
- 1.52 mm
- Noise Level
- 20.6 dBA
- Power Connector
- Rated Voltage
- 12 V
- RoHS
