Design so good, you just can't get enough of it
Taking perfection a notch higher with the stunning EVOL. Design. -
90Hz FHD+ AMOLED Display
Display so fine, it will blow your mind. Brace yourself for an 11 on 10 viewing experience on the splendid AMOLED Display. -
90Hz Refresh Rate - irresistibly smooth
High Refresh Rate of 90Hz means smoother scrolling and graphics resulting in outstanding user experience. -
Sunlight Display
Designed to adjust your screen brightness according to the sunlight. -
Reading Mode 3.0
Designed for eye comfort. -
Qualcomm Snapdragon 680 - efficiency has a new name
Built on 6nm architecture, it is designed to give you superior performance while conserving power. Get ready for 11 on 10 experience! -
Massive 5000mAh Battery 33W Pro Fast Charging - juice up in no time
With 33W Pro Fast Charging and 5000mAh Battery, get ultra-long battery life and improved charging efficiency. -
Turn up the cool quotient
Consistent peak performance with Multiple graphite sheets for heat dissipation. More effective thermal conductivity with an upgraded cooling system and multiple layers of graphite sheets. -
Turn up the volume
Dual stereo speakers. Immersive audio quality.
- Xiaomi Redmi Note 11 - blue star - 4G smartphone - 128 GB - GSM
- Product Type
- 4G smartphone
- Display
- OLED display - 2400 x 1080 pixels - 6.43" - 409 ppi - (90 Hz) - AMOLED
- Processor
- Qualcomm Snapdragon 680 2.4 GHz (8-core)
- Graphics Accelerator
- Qualcomm ADRENO 610
- Memory
- RAM 4 GB / 128 GB
- Supported Memory Card
- microSDXC slot - up to 1 TB
- Operating System
- Android 11 with MIUI 13
- Main Camera
- 50 Megapixel - f/1.8 - focus: automatic
- Second Camera
- 8 Megapixel - ultra wide-angle lens - f/2.2
- Third Camera
- 2 Megapixel - f/2.4 - macro camera
- Fourth Camera
- 2 Megapixel - f/2.4 - depth camera
- Front Camera
- 13 Megapixel f/2.4
- Service Provider
- Not specified
- SIM Card
- Dual-SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth
- Security Devices
- Face recognition, fingerprint reader (side)
- Connectors
- 3.5 mm headset jack, USB-C
- Talk Time
- Up to 2580 minutes
- Protection
- Dustproof, splashproof
- Blue star
- 73.87 mm x 8.09 mm x 159.87 mm
- 179 g
- Specific Absorption Rate (SAR)
- 0.596 W/kg (head) , 0.989 W/kg (body) , 1.996 W/kg (limb)
- 2-year warranty
- Product Type
- Smartphone
- Form Factor
- Touch
- Protection
- 73.87 mm
- 8.09 mm
- 159.87 mm
- 179 g
- Body Colour
- Blue star
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Android 11
- User Interface
- MIUI 13
- Navigation
- GPS, GLONASS, BeiDou, Galileo
- SIM Card Qty
- Dual-SIM
- Input Device
- Multi-touch
Communications
- Data Transmission
- FDD-LTE, TDD-LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 20, Band 28, Band 32, Band 38, Band 40, Band 41
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 800 DD, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 2300, TDD 2500
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0
Phone Features
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, digital compass, gyroscope
- Security Devices
- Security Technology
- AI face unlock
- Additional Features
- Z-axis linear vibration motor, dual stereo speakers, IR blaster, write booster
Media Player
- Sound Enhancements
- Hi-Res audio certified
- Clock Speed
- 2.4 GHz
- Processor Core Qty
- 8-core
Graphics System
- RAM
- LPDDR4X SDRAM - 4 GB
- Internal Memory Capacity
- 128 GB
- Memory Interface
- UFS 2.2
- Supported Flash Memory Cards
- microSDHC, microSD, microSDXC - up to 1 TB
Front Camera
- Sensor Resolution
- 13 Megapixel
- Lens Aperture
- F/2.4
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1280 x 720 (720p) at 30 fps
Main Camera
- Sensor Resolution
- 50 Megapixel
- Lens Aperture
- F/1.8
- Focus Adjustment
- Automatic
- Light Source
- LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 3840 x 2160 (4K) at 30 fps
- AI Quad camera
Second Camera
- Sensor Resolution
- 8 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- Field of View (FoV)
- 118 degree(s)
Third Camera
- Sensor Resolution
- 2 Megapixel
- Lens Aperture
- F/2.4
- Functions
- Macro camera
Fourth Camera
- Sensor Resolution
- 2 Megapixel
- Lens Aperture
- F/2.4
- Functions
- Depth camera
Display
- OLED display
- Technology
- AMOLED
- Diagonal Size
- 6.43"
- Display Resolution
- Display Format
- Full HD+
- Pixel Density
- 409 ppi
- Max Brightness
- 1000 cd/m²
- Enhancement Technology
- Sunlight mode, Reading mode 3.0
- Refresh Rate
- 90 Hz
- Touch Sampling Rate
- 180 Hz
- Contrast Ratio
- 4500000:1
- DCI-P3 Wide colour gamut, Dot Display
- Connector Type
- USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
- Capacity
- 5000 mAh
- Fast Charging Technology
- Pro fast charging
- Talk Time
- 2580 minutes
- Run Time Details
- Talk: up to 2580 min , Playback (video): up to 22 hrs , Playback (audio): up to 215 hrs
- IP53, TUV SUD, SGS, IEC 60529
- Included Accessories
- Power adapter, SIM card removal tool, USB-C cable, protective case
- Limited warranty - 2 years
