Xiaomi Redmi Note 11 Graphite Gray 4+ 128GB
Quicklinx: GQ4CWS00 Mfr#: MZB0AM0EN
Operating system: Android
Model: Note 11
Mobile Connectivity: 4G
Screen Size: 6.43in
Rear Camera: 50 Megapixel
  • microSDHC
  • microSD
  • Android
£158.33 ex VAT
£189.99 inc VAT
The slim and sleek flat frame design of the note 11
Coming in 3 different colours graphite grey, twilight blue and star blue making it perfect for any user. The note 11 has a thickness of just 8.09mm and weight of 179g
Amoled display
  • 6.43" FHD+ Amoled DotDisplay
  • DCI-P3 Wide Colour gamut for rich colour representation
  • 4,500,000:1 Contrast ratio for sharp images
  • Sunlight display, allows the screen to be readable in bright sunlight
  • Reading mode 3.0, Relieves eye strain
Seamless touchscreen and display
Enjoy your content in smooth and seamless 90Hz high refresh rate. Scroll through your social media feeds in comfort or experience powerful and responsive gaming.
All-around performance with the 6nm Snapdragon 680
This processor is not only fast and powerful, but also runs on the energy efficient 6nm process to give you high performance while improving battery life. Faster loading speeds with UFS 2.2 and accelerated writing with the Write Booster — effective high-speed app installation, initiation and file cache functions, as well as large-file reading and writing.
33W Pro fast charging and massive 5000mAh battery
100% charge in just over 1 hour with the 33W pro fast charging
Powerful 50MP Quad Camera System
  • 50MP main camera
  • 8MP ultra-wide camera
  • 2MP Macro camera
  • 2MP Depth camera
Plus, a 13MP Selfie camera
Smarter and more convenient
  • Memory extension
  • Dual Stereo speaker
  • Multifunctional NFC for quick convenient mobile payments
  • IR Blaster for easy control of your home appliances
  • Z axis linear motor for excellent haptic feedback
  • Design so good, you just can't get enough of it
    Taking perfection a notch higher with the stunning EVOL. Design.
  • 90Hz FHD+ AMOLED Display
    Display so fine, it will blow your mind. Brace yourself for an 11 on 10 viewing experience on the splendid AMOLED Display.
  • 90Hz Refresh Rate - irresistibly smooth
    High Refresh Rate of 90Hz means smoother scrolling and graphics resulting in outstanding user experience.
  • Sunlight Display
    Designed to adjust your screen brightness according to the sunlight.
  • Reading Mode 3.0
    Designed for eye comfort.
  • Qualcomm Snapdragon 680 - efficiency has a new name
    Built on 6nm architecture, it is designed to give you superior performance while conserving power. Get ready for 11 on 10 experience!
  • Massive 5000mAh Battery 33W Pro Fast Charging - juice up in no time
    With 33W Pro Fast Charging and 5000mAh Battery, get ultra-long battery life and improved charging efficiency.
  • Turn up the cool quotient
    Consistent peak performance with Multiple graphite sheets for heat dissipation. More effective thermal conductivity with an upgraded cooling system and multiple layers of graphite sheets.
  • Turn up the volume
    Dual stereo speakers. Immersive audio quality.
Snapdragon 680
Storage and Ram
4GB + 128GB Expandable up to 1TB
Dimensions
H: 159.87mm W:73.87mm D:8.09mm Weight 179g
Display
6.43" FHD+ Amoled DotDisplay,
Battery and Charging
5000mAh, 33w pro fast charging, 33W in-box charger, USB-C
Security
Side fingerprint sensor, AI face unlock
NFC
Availability varies between market
Network
Sim Free, Dual Sim + MicroSD
4G, 3G, 2G, Bluetooth 5.0, Wifi
Audio
Dual Speakers, 3.5 headphone jack
Senors
Promximity, Ambient light, Accelerometer, Electronic compass, IR blaster, Gyroscope
Operating system
MIUI 13 based on Android 11
Package contents
Redmi note 11, adapter, USB type C Cable, Sim eject tool, Protective case, Quick start Guide, Warranty card
Model: Note 11
Screen Size: 6.43in
Brand: Xiaomi
