Xiaomi Redmi 10 Carbon Gray 4GB RAM 128GB ROM
Quicklinx: GKD4WS00 Mfr#: MZB09POEN
  • microSDHC
  • microSD
  • Android
Redmi Note 10 is equipped with an advanced linear motor, which intelligently converts various sounds and movements into precise vibration effects, enhancing your gaming and overall usage experience.
Equipped with an AI quad camera, which enables you to explore and capture all the scenes from your daily life in detail. Whether you are shooting vast mountain ranges, distant landmarks or close-up shots, they can all be captured with ease
The body has a curved back, flattened ends and tapered edges to offer a refined, premium appearance
The natural color scheme emphasizes premium simplicity. With its glossy finish, the color can complement your style
The frame makes the phone look even slimmer than it is. With a weight of less than 180g, carrying the phone around is effortless
The redesigned Arc side fingerprint sensor is seamlessly integrated into the body for a comfortable hand feel. Let fast unlocking becomes a habit
Storage 64GB
Ram 4GB
Dimensions Height: 160.46mm, Width: 74.5mm, Thickness: 8.29mm, Weight: 178.8g
Display 6.43" Amoled DotDisplay
Resolution: 2400x1080
409 PPI
Contrast ratio: 4,500,000:1
Brightness: HBM 700 nits (typ), 1100 nits peak brightness (typ)
DCI-P3 color gamut
8-bit color
Reading mode 3.0
Sunlight display 2.0
Low blue light certified by SGS
Processor Qualcomm Sanpdragon 678
Rear Camera 48MP, 8MP, 2MP, 2MP
Front Camera 13MP
Fingerprint Sensor and AI face unlock
  • Always camera-ready
    With the AI quad camera, you are well-equipped for any photo scenario.
  • Get creative with short videos
    Use filters to take your short videos to the next level.
  • Smoother scrolling
    You can enjoy a smoother, more fluid viewing experience when scrolling or playing games.
  • Speakers that impress
    Enjoy a better audio with dual speakers. Listen to music with crisp stereo sound directly from your phone.
  • Power that lasts
    The large battery has enough power to easily get you through the day.
Xiaomi Redmi 10 - carbon grey - 4G smartphone - 128 GB - GSM
4G smartphone
Display
2400 x 1080 pixels - 6.5" - 405 ppi - (90 Hz) - Corning Gorilla Glass 3 (scratch resistant glass)
FM radio
MediaTek Helio G88 2 GHz (8-core)
Graphics Accelerator
ARM Mali-G52
RAM 4 GB / 128 GB
Supported Memory Card
microSDXC slot - up to 512 GB
Operating System
Android 11 with MIUI 12.5
Main Camera
50 Megapixel - f/1.8 - focus: automatic
Second Camera
8 Megapixel - ultra wide-angle lens - f/2.2
Third Camera
2 Megapixel - f/2.4 - macro camera
Fourth Camera
2 Megapixel - f/2.4 - depth camera
Front Camera
8 Megapixel f/2.0
Service Provider
Not specified
SIM Card
Dual-SIM
Wireless Interface
Wi-Fi, Bluetooth
Security Devices
Face recognition, fingerprint reader (side)
Connectors
3.5 mm headset jack, USB-C
Talk Time
Up to 1800 minutes
Carbon grey
75.53 mm x 8.92 mm x 161.95 mm
181 g
0.586 W/kg (head) , 0.978 W/kg (body) , 1.992 W/kg (limb)
Smartphone
Touch
Integrated Components
FM radio
75.53 mm
8.92 mm
161.95 mm
181 g
Body Colour
Carbon grey
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Android 11
User Interface
MIUI 12.5
Navigation
GPS, A-GPS, GLONASS, BeiDou, Galileo
SIM Card Qty
Dual-SIM
Input Device
Multi-touch
Communications
Data Transmission
FDD-LTE, TDD-LTE
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 20, Band 28, Band 38, Band 40, Band 41
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 800 DD, FDD 700 APT, TDD 2600, TDD 2300, TDD 2500
Wireless Interface
Wi-Fi, Bluetooth 5.1
Phone Features
Sensors
Accelerometer, ambient light sensor, proximity sensor, digital compass, vibration motor
Security Devices
Security Technology
AI face unlock
Additional Features
Fast Charging, IR blaster, 9W reverse wired charging
MediaTek Helio G88
Clock Speed
2 GHz
Processor Core Qty
8-core
Graphics System
ARM Mali-G52
RAM
LPDDR4X SDRAM - 4 GB
Internal Memory Capacity
128 GB
Supported Flash Memory Cards
microSDHC, microSD, microSDXC - up to 512 GB
Front Camera
Sensor Resolution
8 Megapixel
Lens Aperture
F/2.0
Camera Modes
Selfie panorama
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1280 x 720 (720p) at 30 fps
Main Camera
Sensor Resolution
50 Megapixel
Lens Aperture
F/1.8
Focus Adjustment
Automatic
Light Source
Flash
Video Resolutions
AI Quad camera
Second Camera
Sensor Resolution
8 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Field of View (FoV)
120 degree(s)
Third Camera
Sensor Resolution
2 Megapixel
Lens Aperture
F/2.4
Functions
Macro camera
Fourth Camera
Sensor Resolution
2 Megapixel
Lens Aperture
F/2.4
Functions
Depth camera
Display
Diagonal Size
6.5"
Display Resolution
2400 x 1080 pixels
Display Format
Full HD+
Pixel Density
405 ppi
Enhancement Technology
Reading mode 3.0
Refresh Rate
90 Hz
Protection
Sunlight Display, Dot Display, AdaptiveSync technology
Connector Type
USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
5000 mAh
Talk Time
1800 minutes
Run Time Details
Talk: up to 1800 min , Playback (video): up to 14 hrs , Playback (Music): up to 158 hrs
SIM card removal tool, USB-C cable, protective case, 22.5W power adapter
