Xiaomi Mi Wireless Outdoor Security Camera & Receive 1080p Set
Quicklinx: GPVPWS00 Mfr#: BHR4435GL
Easy wire-free installation High-resolution monitoring
3 Step pairing
- Open the Mi Home/Xiaomi Home App
- Scan the QR code on the indoor receiver through the home app to pair the device
- Scan the QR code on the outdoor camera through the home app to finish pairing
130° wide angle, wider angle, larger area
Capture more with 130 degree wide angle, see what happens around your house in 1080p high resolution.
WDR technology + Smart night vision
With WDR technology and F 2.1 large aperture, the camera can record clear detailed images even in darkness and backlight. Night vision distance up to 7m, display the outdoor environment clearly at night
One indoor receiver can support up to 4 outdoor cameras
Multiple cameras can be operating at the same time and recording every corner around the house from any angle. You can check images of four cameras on your smartphone at the same time, and can also tap one image to check the details, keeping an eye on your house from anywhere.
Reliable monitoring day and night
IP65 dust and water resistance
Reliable in hot and cold weather (temperatures ranging from -20°C to 50°C)
Anti-theft design (The camera features an anti-theft screw structure and a built-in gyroscope. If abnormal activity is detected, a real-time alert will be sent to your phone.)
Smart protection, convenient viewing
Human Detection
Intercom voice changer
Independant indoor receiver
H.265 video encofinh
Real-time alert in case of abnormal activity outside
Starts recording and sends notifications if an unexpected temperature change and unusual activity within 7m are detected. Smart human detection, real-time alert.
Independent indoor receiver, Multiple storage options
The indoor receiver can store videos via local TF card, USB drive and/or 3-day rolling cloud storage, to meet your video storage need and prevent information loss and leakage.
Adopts the new-generation H.265 video encoding technology, save more storage space, view seamless images in fast and stable connection with the new-generation H.265 video encoding technology without having to upgrade your network
In the box
- Mi Wireless Outdoor Security Camera 1080p (including battery) ×1
- Wall Plug x 3
- Indoor receiver ×1
- Screw x 3
- Mounting Template Sticker x 1
- User manual ×1
- Charging Cable (1m) x 1
- Warranty Notice x 1
- Ethernet Cable (2m) x 1
- Attention Sticker x 1
  • Capture clear details of outdoor conditions in Full HD
    One indoor receiver supports up to four outdoor cameras connection, for simultaneous recording.
  • Wider angle, larger area
    Capture more area with 130° wide angle, see what's happening around your house in 1080p high resolution.
  • WDR technology + smart night vision
    With WDR technology and F 2.1 large aperture, the camera can record clear detailed images even in darkness and backlight. The long night vision distance allows to display the outdoor environment clearly at night.
  • One indoor receiver can support up to 4 outdoor cameras connection
  • Stable and reliable even in different temperatures
    With a wide operating temperature range, the camera can work normally at temperatures ranging from -20°C to 50°C, guarding your house all year round.
  • Anti-theft design
  • Real-time alert in case of abnormal activity outside
    It starts recording and sends notifications if an unexpected temperature change and unusual activity within 7m are detected.
  • Independent indoor receiver
    The indoor receiver can store videos via local TF card, USB drive and/or 3-day rolling cloud storage, to meet your video storage need and prevent information loss and leakage. It adopts the H.265 video encoding technology, save more storage space, view seamless images in fast and stable connection with the H.265 video encoding technology without having to upgrade your network.
Xiaomi MI Wireless Outdoor Security Camera 1080p (Set Version) - network surveillance camera
Network surveillance camera - fixed - outdoor - dustproof / waterproof
5.27 cm x 12.2 cm x 10.26 cm
273 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Video Modes
1080p
Lens Iris
F/2.1
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
1 - charging cable - 1 m , 1 - network cable - 2 m
Wide Dynamic Range (WDR), built-in gyroscope, human detection
Environmental Parameters (operating)
-20 °C - 50 °C
Wireless
5.27 cm
12.2 cm
10.26 cm
273 g
Camera
Colour - Day&Night - fixed - outdoor - dustproof / waterproof
Digital Video Format
H.265
Max Digital Video Resolution
1920 x 1080
Video Modes
1080p
Infrared LEDs
8
Infrared Distance
7 m
Digital Video Capture Resolution
1920 x 1080
Lens Construction
Lens Iris
F/2.1
Horizontal Field of View (degree)
130
Network Interface
Ports
USB (power only)
Wireless receiver, 3 wall plugs, attention sticker, mounting template sticker
1 x charging cable - 1 m , 1 x network cable - 2 m
IP65
5700 mAh (up to 90 days)
Android 6.0 (Marshmallow) or later, Apple iOS 10 or later
-20 °C
50 °C
