High-precision sensors accurately sense how the body changes every day
Mi Smart Scale 2 uses a high-precision manganese steel sensor, which can accurately sense subtle changes down to 50g. Every meal you eat and every glass of water you drink can be easily quantified, and displayed as kilograms, jin, or pounds, effectively helping you to finely manage information about your weight
Mi Fit APP renders your movement curve
Open the Mi Fit APP and you can view curve plots of your data and body changes anytime and anywhere. You can clearly see your transformation process. You can also make fitness plans and dietary adjustments based on your BMI (Body Mass Index). Also, your weight data will be automatically uploaded to the cloud each time via the APP and stored, with there being no limit.
Lower weight is not necessarily better. Keeping an ideal weight is healthiest.
Mi Smart Scale 2 is equipped with an ideal weight measurement function, which intelligently calculates your weight based on your height, age, BMI, and other data, so that you don’t have to lose weight recklessly and become excessively thin for the sake of aesthetics.
To maintain a stable body, being able to balance oneself is essential
Balance is a basic physical ability. Improving balance can reduce the risk of falls and joint injuries. Mi Smart Scale 2 is equipped with a body balance ability test. Standing on the scale with one foot and eyes closed, you can learn about your body balance ability using the APP
Weighing people and objects, smart switching for weighing mailing parcels, and daily necessities, any time
In addition to weighing the human body, the Mi Smart Scale 2 can also meet the needs of weighing small objects, and can measure still objects weighing as little as 100g after activation. Did the fruit you bought weigh the right amount? How much does the package you plan to send weigh? Solve the small problems of everyday weighing.
Bluetooth 5.0 provides a faster, more stable connection
Mi Smart Scale 2 uses Bluetooth Low Energy 5.0, so the weight data transmission is faster and more stable. Cherish every second of your time.
- Xiaomi Mi Smart Scale 2 Body Composition - bathroom scales - white
- Product Type
- Bathroom scales - electronic
- Maximum Weight
- 150 kg
- White
- 30 cm x 30.5 cm x 2.5 cm
- 1.7 kg
- 2 years
- Product Type
- Category
- Health control
- White
Scales
- Maximum Weight
- 150 kg
- Graduation
- 100 g
- Measuring Functions
- Body water percentage, body fat percentage, body mass index (BMI), muscle mass, bone mass, basal metabolic rate (BMR), visceral fat, metabolic age, protein
- Platform Material
- Tempered glass
Settings, Controls & Indicators
- Smartphone Compatible
Display
- LED display
Internet of Things (IoT)
- Communications Technology
- Bluetooth
- Material
- ABS plastic
- Power Source
- Battery
- Battery Life
- Up to 1 year
- Battery Form Factor
- AAA
- Required Battery Qty
- 4
- 30 cm
- 30.5 cm
- 2.5 cm
- 1.7 kg
- Width (Shipping)
- 35 cm
- Depth (Shipping)
- 35 cm
- Height (Shipping)
- 5 cm
- Weight (Shipping)
- 2.4 kg
- Warranty
- 2 years
