Xiaomi 13 Pro Ceramic Black 12GB RAM 256GB ROM
Quicklinx: H6R0WS00 Mfr#: MZB0DB1EN
Xiaomi 13 Pro is the latest realisation of our imaging philosophy and the masterpiece behind the masterpiece. Professional optics, emotive imaging aesthetics and full Leica experience are embodied in the device to bridge the century old imaging legends and the masterpieces you are creating today.
Designed to master and last
The body design is exquisitely curved back and front. Enjoy Corning® Gorilla® Glass Victus® on the front as your tough screen. Enjoy medical-grade bio-ceramic material on the back, that not only adds a soft touch to the streamlined structure, but also highlights the design definition of a flagship: a masterpiece that balances profession, elegance, and toughness.
A reliable ally for creating masterpieces in more environments
The device is durable at the professional level with IP68 water and dust resistance. Let your defining moment be found anywhere in the world, whether on the deck of a swaying sailboat or in the heart of the desert.
This is masterpiece imaging
Introducing the Leica professional optical lens system, in which complex and sophisticated optics previously only experienced in traditional photography are now available on your Xiaomi 13 Pro.
8 element lens. Improving light transmitting
Lens edge ink coating. Reducing the reflection of light to improve imaging definition
Cyclic olefin copolymer. Reducing purple fringing
Anit-glare coating. ALD ultra-low reflectance technology
IR filters. Absorbing infrared light
The professional studio behind the masterpiece system
HyperOIS. More stable video recording
4K Ultra night Video. Your story remains clear and smooth even when the light is dim
Creat in Dolby Vision. Record the vivid details as if the story were happening in front of you again.
  • Behind the masterpiece
    Xiaomi 13 Pro is the latest realization of imaging philosophy and the masterpiece behind the masterpiece. Professional optics, emotive imaging aesthetics and full Leica experience are embodied in the device to bridge the century old imaging legends and the masterpieces you are creating today.
  • A design that forged a masterpiece identity
    The body design is exquisitely curved back and front. Enjoy Corning Gorilla Glass Victus on the front as your tough screen. Enjoy medical-grade bio-ceramic material on the back, that not only adds a soft touch to the streamlined structure, but also highlights the design definition of a flagship: a masterpiece that balances profession, elegance, and toughness.
  • A reliable ally for creating masterpieces in more environments
  • The professional optics
  • Discover the components of a masterpiece camera
    Each component can enhance the quality of your lens from the ground up to achieve incredible more light transmission, allowing you to create masterpieces in any lighting conditions.
  • Absorbing infrared light
    The 1-inch ultra-large sensor provides a massive light-sensitive area, more powerful light absorption and better imaging resolution. Every shot, whether it's in the dim light or on the move, has a fine and clear texture.
  • The masterpieces in the dim light
    The sensor produces ultra clean images even in low light conditions without relying on heavy noise reduction algorithm. Thus the works can preserve colors, textures and details.
  • The masterpieces on the move
    The sensor increases the light absorption, enabling better captures. It also allows an optical level 2x zoom for clearer snapshots.
  • The telephoto that can float to capture the moments
    Inspired by DSLR professional lens, the telephoto lens on Xiaomi 13 Pro is divided into two units and can be moved internally to achieve telephoto and macro photography.
  • Shoot at 75mm focal length
    The focal shift lens module moves forwards to capture just the right amount of details, emotions and space for portraits
  • Focus fast on the details in the masterpieces
    With Focal Shift technology also driven by Xiaomi Imaging Engine, Xiaomi ProFocus goes even further to support animal eye tracking and capture more precise details in snapshots.
  • Two professional narrative styles of your masterpieces
    Inspired by the classic aesthetic of Leica, Xiaomi 13 Pro employs two unique photographic styles from Leica and achieves P3 color gamut for true-to-life color accuracy.
  • Leica vibrant look
    The look makes the image vivid while still being natural via moderate brightening and saturation adjustment.
  • Leica filters, top picks
    Offering a collection of choices of filters to fine-tune the colors, make your story more compelling but still preserve the delicate transitions of the originals.
  • Enjoy creating masterpieces with the touch of Leica
    You may experience professionalism and passion every moment you shoot with Xiaomi 13 Pro, whether it's the shutter button you press, the shutter sound from the M-series, or the classic Leica watermark on your masterpiece.
Xiaomi 13 Pro - ceramic black - 5G smartphone - 256 GB - GSM
5G smartphone
Display
OLED display - 3200 x 1440 pixels - 6.73" - (120 Hz) - 20:9 - AMOLED (LTPO) - HDR - Corning Gorilla Glass Victus (scratch resistant glass)
Qualcomm Snapdragon 8 Gen 2 3.19 GHz (8-core)
Graphics Accelerator
Qualcomm ADRENO
RAM 12 GB / 256 GB
Operating System
Android 13 with MIUI 14
Main Camera
50 Megapixel - Sony IMX989 sensor - f/1.9 - focus: automatic
Second Camera
50 Megapixel - floating telephoto lens 10 cm - f/2.0
Third Camera
50 Megapixel - ultra wide-angle lens - f/2.2
Front Camera
32 Megapixel f/2.0
Service Provider
Not specified
SIM Card
Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
Wireless Interface
NFC, Bluetooth, Wi-Fi 7
Security Devices
Fingerprint reader (under display), face recognition
Connectors
USB-C
Protection
Water-resistant, splash-resistant, dust-resistant
Ceramic black
74.6 mm x 8.38 mm x 162.9 mm
229 g
0.998 W/kg (head) , 0.998 W/kg (body) , 2.588 W/kg (limb)
Smartphone
Touch
Protection
74.6 mm
8.38 mm
162.9 mm
229 g
Body Colour
Ceramic black
Body Material
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
5G
Service Provider
Not specified
Operating System
Android 13
User Interface
MIUI 14
Navigation
GPS, A-GPS, GLONASS, BeiDou, Galileo, NavIC
SIM Card Type
Nano SIM, Electronic SIM card (e-SIM)
SIM Card Qty
Dual-SIM
Input Device
Multi-touch
Communications
Data Transmission
FDD-LTE, TDD-LTE, 5G NR FR1
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 6, Band 8, Band 19
3G UMTS Frequency
2100, 1900, 1700, 850, 800, 900, 800
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 42, Band 48, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, TDD 3500, TDD 3600, FDD 1700 - 2110 AWS-3
5G NR Band
N1, n3, n5, n7, n8, n20, n28, n38, n41, n66, n71, n75, n77, n78, n79, n40
5G NR Frequency
FDD 2100, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, FDD AWS-3, FDD 600, SDL DL 1500+, TDD TD 3700, TDD TD 3500, TDD TD 4500, TDD 2300
Wireless Interface
NFC, Bluetooth 5.3, IEEE 802.11a/b/g/n/ac/ax/be
Phone Features
Sensors
Accelerometer, proximity sensor, digital compass, barometer, flicker sensor, gyroscope, 360° ambient light sensor
Security Devices
Security Technology
AI face unlock
Additional Features
MIMO technology, MU-MIMO technology, LiquidCool Technology, Reverse wireless charging, dual stereo speakers, X-axis linear vibration motor, IR blaster, Qualcomm FastConnect 7800, Xiaomi Surge charging chipset, Xiaomi Surge battery management chipset, Xiaomi surge battery management system
Media Player
Supported Digital Audio Standards
WAV, AAC, AMR, MP3, FLAC, OGG, APE (Monkey's Audio), LDAC, AWB, LHDC
Supported Digital Video Standards
MKV, 3GP, WebM, MP4
Video Enhancements
HDR with Dolby Vision, HDR10
Sound Enhancements
Dolby Atmos sound technology, Hi-Res audio certified, Hi-Res audio wireless
Clock Speed
3.19 GHz
Processor Core Qty
8-core
Graphics System
Qualcomm ADRENO
RAM
LPDDR5X SDRAM - 12 GB
Internal Memory Capacity
256 GB
Memory Interface
UFS 4.0
Front Camera
Sensor Resolution
32 Megapixel
Lens Aperture
F/2.0
Field of View (FoV)
89.6 degree(s)
Pixel Size
0.7 µm
Special Effects
HDR
Camera Modes
Night mode, Vlog mode, AI portrait mode with bokeh and depth control, Video teleprompter
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1280 x 720 (720p) at 30 fps
4-in-1 to 1.4µm Super Pixel, Dynamic Framing (0.8x / 1x)
Main Camera
Sensor Resolution
50 Megapixel
Sensor Size
1"
Sensor Name
Sony IMX989 sensor
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Aperture
F/1.9
Lens Construction
8-element
Focal Length Equivalent to 35mm Camera
23mm
Pixel Size
1.6 µm
Focus Adjustment
Automatic
Digital Zoom
70x
Special Effects
HDR, Leica Authentic Look, Leica Vibrant Look, Leica filters, Leica classica shutter sound, Leica Watermark
Camera Modes
Slow motion video, Panorama, Pro mode, night mode, Slow Shutter, Clone, Documents, Vlog mode, Pro Video mode, Night portrait mode, supermoon mode, Ultra Night Video, Magic Zoom, Time Freeze, Night Time-lapse, Parallel World, Freeze Frame Video, Long exposure mode, Lightning Burst
Face Detection
Face recognition
Light Source
LED flash
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, 3840 x 2160 (4K) at 24 fps, 7680 x 4320 (8K) at 24 fps
HDR video recording, Xiaomi ProFocus, Leica professional optical lens, Vario-Summicron 1:1.9-2.2/14-75 ASPH, 3.2µm 4-in-1 Super Pixel, HyperOIS, 35mm black and white lens, 50mm swirly boken lens, 75mm portrait lens, 90mm soft focus lens, lens edge ink coating, Cyclic olefin copolymer, ALD ultra-low reflectance technology, IR filters, 10-bit RAW
Second Camera
Sensor Resolution
50 Megapixel
Lens Type
Floating telephoto lens
Lens Aperture
F/2.0
Min Focal Length
10 cm
75mm
Lens Element Qty
6-element
10cm macro photography, Focal Shift technology
Third Camera
Sensor Resolution
50 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
14mm
Field of View (FoV)
115 degree(s)
5cm macro photography
Display
OLED display
AMOLED (LTPO)
Diagonal Size
6.73"
Display Resolution
3200 x 1440 pixels
Display Format
WQHD+
Aspect Ratio
20:9
Max Brightness
1900 cd/m²
Colour Depth
1.07 billion colours
HDR
HDR Technology
HDR10+
Enhancement Technology
Dolby Vision
Refresh Rate
120 Hz
Touch Sampling Rate
240 Hz
Protection
DCI-P3 Wide colour gamut, True Colour, AdaptiveSync Pro, 3D Curved display, JNCD 0.21, Delta-E 0.28
Connector Type
USB Type-C - 24 pin USB-C
4820 mAh
Fast Charging Technology
Xiaomi HyperCharge technology
Wireless Charging
Recharge Time
19 min
IP68, IEC 60529:1989+A1:1999+A2:2013
SIM card removal tool, USB-C cable, protective case, 120W charger
Max Depth of Water Resistance
1.5 m
