With the 6000 series, XFX is literally putting you in the game. The AMD Radeon HD 6870 is 3-D ready and one of the first HDMI and DisplayPort 1.2 solutions for Stereoscopic 3-D on the market.
The AMD Radeon HD 6870 ushers in a new era of gaming that takes users to an entirely new level. The AMD 3-D experience is truly immersive and seamless. AMD has also teamed up with other Open 3-D ecosystem partners to provide consumers with more choice, more innovation and lower cost.
Along with this series XFX debuts the 3E Trilogy, incorporating AMD Eye-Definition (utilizing AMD's HD3D technology & DirectX 11 for explosive performance and stunning effects), AMD Eyefinity (which supports multi-display gaming) and AMD Eyespeed (improves video image quality and application performance for amazing visuals) technologies.
Specification
- Chipset version ATI Radeon HD 6870
- GPU Clock 900 MHz
- Memory Bus 256 bit
- Memory Clock 4.2 GHz
- Memory Size 2 GB
- Memory Type DDR5
- External Power - 6-Pins 2
- Minimum Power Supply Requirement 500 Watt
- Output - DL-DVI-I 1
- Output - HDMI 1
- Output - mini DP 2
- Output - SL-DVI-D 1
- Thermal Solution Dual fan Fansink
- Thermal Type Dual slot
- AMD - CrossFire ready Y
- AMD Eyefinity Technology Y
- AMD HD3D Technology Y
- Display Port ready 1.2
- Dual link Support Y
- HDMI Ready 1.4a
- Max Supported Resolution (ANALOG) 2048 x 1536
- Max Supported Resolution (DIGITAL) 2560 x 1600
- XFX Recommended Power Supply XFX 650W PSU
- Double Dissipation Cooling Technology Y
- Card Profile Dual
- Driver CD Installation Guide 1
- Installation CD with Multi-Language User Guide 1
- Quick Installation Guide 1
- XFX Serial Number Door Hanger 1
- Card Dimension (cm) 26.2 x 11.12 x 3.81
- Card Dimension (inch) 10.3 x 4.4 x 1.5
3nd generation TeraScale graphics engine
Massive arrays of on-chip compute units offer the latest in graphics functionality and performance. This provides increased processing power for the latest games and accelerated applications. -
AMD CrossFireX
The ultimate multi-graphic card performance gaming platform. Enabling game-dominating power, AMD CrossFireX technology enables two or more discrete graphics cards to work together to improve system performance. For The Ultimate Visual Experience, be sure to select AMD CrossFireX ready motherboards for AMD and Intel processors and multiple AMD Radeon HD graphics cards. It allows you the ability to scale your system's graphics horsepower as you need it, supporting up to four AMD Radeon HD graphics cards. -
AMD Advanced Parallel Processing technology
Boost system performance by offloading task from the CPU to the GPU. It makes your video encoding and transcoding process quick and easy. -
HDMI
HDMI combines digital video and audio in a single consumer-friendly connector. HDMI delivers a clear clean image at any window size, including full-screen high-definition resolutions up to 1080p. -
AMD Eyefinity technology
Enjoy the ultimate immersive gaming experience with innovative "wrap around" multi-display capabilities. Run up to three displays from a single graphics card and expand your gaming field of view across all displays. -
AMD HD3D technology
Full support for stereoscopic 3D, that creates three-dimensional depth on 2D imagery (movies, games, photos). Experience high quality Blue-ray movies, video games and photos in 3D. -
DisplayPort 1.2
DisplayPort is designed to be the future-ready, scalable solution for high performance digital display connectivity. It enables the highest resolutions, the fastest refresh rates and deepest color depths over standard cables. V1.2 update enables increased bandwidth plus stereo 3D support.
- Graphics Processor Manufacturer
- AMD
- AMD Radeon HD 6870
- Interface
- PCI Express 2.1 x16
- Memory Size
- 2 GB
- Digital Output
- Digital Visual Interface (DVI), DisplayPort, High-Definition Multimedia Interface (HDMI)
- Core Clock
- 900 MHz
- Header / Compatibility
- PC
- Header / Manufacturer
- XFX
- Header / Model
- Radeon HD 6870
- Header / Product Line
- XFX
- Memory Type
- GDDR5 SDRAM
