XFX ATI Radeon 6870 HD 940MHz 1GB PCI-E HDMI Black Edition
Quicklinx: 78D9WS00 Mfr#: HD-687A-ZNBC
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
With the 6000 series, XFX is literally putting you in the game. The AMD Radeon HD 6870 is 3-D ready and one of the first HDMI and DisplayPort 1.2 solutions for Stereoscopic 3-D on the market.
The AMD Radeon HD 6870 ushers in a new era of gaming that takes users to an entirely new level. The AMD 3-D experience is truly immersive and seamless. AMD has also teamed up with other Open 3-D ecosystem partners to provide consumers with more choice, more innovation and lower cost.
Along with this series XFX debuts the 3E Trilogy, incorporating AMD Eye-Definition (utilizing AMD's HD3D technology & DirectX 11 for explosive performance and stunning effects), AMD Eyefinity (which supports multi-display gaming) and AMD Eyespeed (improves video image quality and application performance for amazing visuals) technologies.
  • 3nd generation TeraScale graphics engine
    Massive arrays of on-chip compute units offer the latest in graphics functionality and performance. This provides increased processing power for the latest games and accelerated applications.
  • AMD CrossFireX
    The ultimate multi-graphic card performance gaming platform. Enabling game-dominating power, AMD CrossFireX technology enables two or more discrete graphics cards to work together to improve system performance. For The Ultimate Visual Experience, be sure to select AMD CrossFireX ready motherboards for AMD and Intel processors and multiple AMD Radeon HD graphics cards. It allows you the ability to scale your system's graphics horsepower as you need it, supporting up to four AMD Radeon HD graphics cards.
  • AMD Advanced Parallel Processing technology
    Boost system performance by offloading task from the CPU to the GPU. It makes your video encoding and transcoding process quick and easy.
  • HDMI
    HDMI combines digital video and audio in a single consumer-friendly connector. HDMI delivers a clear clean image at any window size, including full-screen high-definition resolutions up to 1080p.
  • AMD Eyefinity technology
    Enjoy the ultimate immersive gaming experience with innovative "wrap around" multi-display capabilities. Run up to three displays from a single graphics card and expand your gaming field of view across all displays.
  • AMD HD3D technology
    Full support for stereoscopic 3D, that creates three-dimensional depth on 2D imagery (movies, games, photos). Experience high quality Blue-ray movies, video games and photos in 3D.
  • DisplayPort 1.2
    DisplayPort is designed to be the future-ready, scalable solution for high performance digital display connectivity. It enables the highest resolutions, the fastest refresh rates and deepest color depths over standard cables. V1.2 update enables increased bandwidth plus stereo 3D support.
XFX Radeon HD 6870 - Black Edition - graphics card - Radeon HD 6870 - 1 GB
Graphics card
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD Radeon HD 6870
1 GB GDDR5
Core Clock
940 MHz
Effective Memory Clock
4.6 GHz
Memory Interface
256-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / DisplayPort: 2560 x 1600 / HDMI: 2560 x 1600 / VGA: 2048 x 1536
2 x DVI-I , HDMI , 2 x Mini DisplayPort
API Supported
DirectX 11, OpenCL, OpenGL 3.2, DirectCompute 11
3.8 cm x 26.2 cm x 11.2 cm
Graphics card
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD Radeon HD 6870
Core Clock
940 MHz
Max Resolution
2560 x 1600
API Supported
ATI CrossFireX Technology, ATI PowerPlay technology, Video Transcoding (AVT), AMD Eyefinity Technology, AMD HD3D Technology, AMD Accelerated Parallel Processing (APP) Technology, AMD Eyespeed
Size
1 GB
GDDR5 SDRAM
Effective Clock Speed
4.6 GHz
Bus Width
256-bit
Linux, FreeBSD, Microsoft Windows Vista / XP / 7
Required Power Supply
500 W
Additional Requirements
Additional power connector, adjacent PCI slot, PCIe slot
System Requirements Details
Windows XP/Vista/7 RAM 1 GB
CrossFire bridge, 2 x 6 pin power cables, XFX Serial Number door hanger
Software Included
Drivers & Utilities
RoHS
3.8 cm
26.2 cm
11.2 cm
