XFX ATI Radeon 6790 HD 840MHz 1GB PCI-E HDMI 1 x DP
Quicklinx: 7L8WWS00 Mfr#: HD-679X-ZRFC
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
Seriously step up your gaming by kicking it up to the high level with the XFX AMD Radeon HD 6790. Don't miss out on a single frame of stunningly realistic HD gaming as AMD offers crisp imagery for a truly immersive experience. With a low price point, this high-powered graphics card offers an unbeatable value with uncompromising performance.
XFX AMD Radeon HD 6790 comes equip with the XFX dual fan system, providing better cooling, less noise and better capability for overclocking performance. Enjoy your games in full stereo 3D and get incredibly rich and interactive game play with AMD's HD3D technology. Experience Blu-ray 3D in its entirety and take advantage of XFX Radeon HD 6790 graphics support for Dolby TrueHD and 3D HDTV to create that theater quality experience.
The XFX AMD Radeon HD 6790 graphics card also utilizes AMD's Eyefinity and EyeSpeed technologies which support unparalleled visual acceleration and the ability to experience games and various multi media on up to three screens simultaneously.
Package Contents
  • 6-pin to 4-pin power cable 0
  • Driver CD Installation Guide 1
  • Installation CD with Multi-Language User Guide 1
  • Quick Installation Guide 1
  • XFX Serial Number Door Hanger 1
Estimated Dimensions And Weights
  • Card Dimension (cm) 23.5 x 11.12 x 3.81
  • Card Dimension (inch) 9.25 x 4.4 x 1.5
  • Bus Type PCI-E 2.1
  • Chipset HD6790
  • External Power - 6-Pins 1
  • GPU Clock 840 MHz
  • Memory Bus 256 bit
  • Memory Clock 4.2 GHz
  • Memory Size 1 GB
  • Memory Type DDR5
  • Minimum Power Supply Requirement 500 Watt
  • Stream Processors 800
  • Thermal Solution Fansink
  • XFX Recommended Power Supply XFX 550W PSU
Outputs
  • Dual link Support Y
  • Max Supported Resolution (ANALOG) 2048 x 1536
  • Max Supported Resolution (DIGITAL) 2560 x 1600
  • Output - Display Port 1
  • Output - DL-DVI 1
  • Output - HDMI 1
  • Output - SL-DVI 1
  • AMD - CrossFire ready Y
  • AMD Advanced Parallel Processing Technology (APP) Y
  • AMD Avivo HD Y
  • AMD Eyefinity Technology Y
  • AMD HD3D Technology Y
  • AMD Hybrid Graphics Technology Y
  • AMD PowerPlay Technology Y
  • AMD Stream Technology Y
  • HDMI Ready Y
  • Microsoft® DirectX® 11
  • Card Profile Dual
  • Microsoft DirectX 11 support
    The standard for today's PCs and consoles enables stunning and complex effects for cinematic realism. XFX graphics card offers the complete implementation of the shader model feature set-including vertex texture fetch (VTF) - to ensure top-notch compatibility and performance for all DirectX applications.
  • Shader 5 model support
    It enables stunning and complex special effects. The shader architecture delivers faster and smoother gameplay.
  • OpenGL 4.1 optimization and support
    It ensures top-notch compatibility and performance for OpenGL applications.
  • Cooling fan-sink
    Sometimes known as an active cooling device, a small electrical fan drives air across a heat sink and as such will generate a small amount of noise. It is more effective than a heat sink alone at cooling.
  • Double profile
    This graphics card has the capability to swap out the current bracket to make it compatible with low-profile computer systems that require a lower bracket card.
  • ATI Radeon CrossFireX technology
    ATI CrossFireX technology with up to quad GPU support offers superior scalability so your system is ready to level up when you are.
  • ATI Radeon PowerPlay
    Advanced power management technology is designed for optimal performance and power savings. Performance-on-demand allows you to constantly monitor GPU activity and dynamically adjust clocks and voltage based on user scenarios.
  • ATI Eyefinity technology
    Enjoy the ultimate immersive gaming experience with innovative "wrap around" multi-display capabilities. Run up to 3 displays from a single graphics card and expand your gaming field of view across all displays.
  • 1 DisplayPort
    DisplayPort is designed to be the future-ready, scalable solution for high performance digital display connectivity. It enables the highest resolutions, the fastest refresh rates and deepest color depths over standard cables.
XFX Radeon HD 6790 - graphics card - Radeon HD 6790 - 1 GB
Graphics card
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD Radeon HD 6790
1 GB GDDR5
Core Clock
840 MHz
Effective Memory Clock
4.2 GHz
Memory Interface
256-bit
Max Resolution
2560 x 1600
Max Monitors Supported
3
2 x DVI-I , HDMI , DisplayPort
API Supported
DirectX 11, OpenGL 4.1
11.1 cm x 23.5 cm x 3.8 cm
Graphics card
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD Radeon HD 6790
Core Clock
840 MHz
Max Resolution
2560 x 1600
3
API Supported
ATI Stream technology, AMD Eyefinity Technology, AMD HD3D Technology, AMD Accelerated Parallel Processing (APP) Technology, AMD PowerPlay technology, AMD CrossFireX Technology, fan-cooled heatsink, AMD Unified Video Decoder (UVD) 3
Size
1 GB
GDDR5 SDRAM
Effective Clock Speed
4.2 GHz
Bus Width
256-bit
Linux, FreeBSD, Microsoft Windows Vista / XP / 7
Required Power Supply
500 W
Additional Requirements
Two additional power connectors, adjacent PCI slot
System Requirements Details
RAM 1 GB
Software Included
Drivers & Utilities
11.1 cm
23.5 cm
3.8 cm
