Enjoy the latest gaming titles with this fully Microsoft DirectX 11-compatible GPU which offers mind-blowing lifelike HD graphic detail and real Stereoscopic 3D gaming, for a truly immersive HD gaming experience. Expand your visual real estate with ATI Eyefinity Multi-Display Technology which lets you see more and dominate the battlefield. Now with AMD App Acceleration, you can power through even the most bandwidth-hungry media rich applications with blazing speeds. Whether it's gaming or productivity, this card can do it all.
Specification
- GPU Clock 850 MHz
- Memory Bus 128 bit
- Memory Clock 4.8 GHz
- Memory Size 1 GB
- Memory Type DDR5
- External Power - 6-Pins 1
- External Power - 8-Pins 0
- Minimum Power Supply Requirement 500 Watt
- Output - mini DP 5
- Thermal Solution Fansink
- AMD - CrossFire ready Y
- AMD Eyefinity Technology Y
- AMD HD3D Technology Y
- Dual link Support Y
- HDMI Ready Y
- Low Profile Compatible N
- Max Supported Resolution (ANALOG) 2048 x 1536
- Max Supported Resolution (DIGITAL) 2560 x 1600
- XFX Recommended Power Supply XFX 650W XXX edt PSU
- Card Profile Single
- Driver CD Installation Guide 1
- Game Bundle HAWX
- Installation CD with Multi-Language User Guide 1
- Quick Installation Guide 1
- XFX Serial Number Door Hanger 1
- Card Dimension (cm) 22.46 x 11.12 x 1.9
- Card Dimension (inch) 8.8 x 4.4 x 0.75
Get immersed in gaming, productivity and entertainment on up to six displays simultaneously. Supporting multiple independent display outputs simultaneously, AMD Eyefinity technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience. -
Get amazing Eye-Definition graphics with DirectX 11 technology. DirectX 11 is the very latest in high-speed, high-fidelity gaming and computing. Featuring technologies like Compute Shaders, Direct2D, Multithreaded Rendering and Tessellation, DirectX 11 can enable not just more visually stunning games, but significant performance improvements in some of your favorite websites and everyday applications. -
AMD EyeSpeed Technology
Speed up applications and enjoy brilliant video with AMD EyeSpeed visual acceleration.
- XFX Radeon HD 6770 - graphics card - Radeon HD 6770 - 1 GB
- Graphics card
- Bus Type
- PCI Express 2.1 x16
- Graphics Engine
- AMD Radeon HD 6770
- Memory
- 1 GB GDDR5
- Core Clock
- 850 MHz
- Effective Memory Clock
- 4.8 GHz
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI: 2560 x 1600 / VGA: 2048 x 1536
- 5 x Mini DisplayPort
- API Supported
- DirectX 11, OpenGL 4.1
- 2-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 850 MHz
- Max Resolution
- 2560 x 1600
- API Supported
- Avivo HD Technology, AMD Eyefinity Technology, AMD PowerPlay technology, AMD CrossFireX Technology, fan-cooled heatsink, AMD Stream technology
- Size
- 1 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 4.8 GHz
- Required Power Supply
- 450 W
- Software Included
- Tom Clancy's H.A.W.X.
- Limited warranty - 2 years
