XFX AMD Radeon R7 250 Boost 2GB PCI-Express 3.0 HDMI
Quicklinx: 92ZQWS00 Mfr#: R7-250A-CLF4
  • AMD Radeon R7 250
  • High-Definition Multimedia Interface (HDMI)
The Radeon R7 250 GPUs are packed with incredible features and unprecedented performance. These advanced graphics cards feature the award-winning GCN Architecture for spectacular performance and efficiency. Equipped with the latest technologies, they deliver enhanced performance to accelerate your game & multimedia applications - why settle for anything less?
  • The XFactor - see the XFX difference
    Quality components, greater durability, pro components and dust-free fan.
  • Maximize your gaming experience
    Multi-monitor and stereoscopic 3D.
  • Multi-monitor gaming
    See more real-life peripheral vision around sides and see enemies you would have missed in single monitor gaming.
  • 4K resolutions
    Super high resolution ready for tomorrow's applications and screens.
  • Superb gaming graphics
    Fully supported Microsoft DirectX 11.2, with 4x faster tessellation rendering and massive virtual texture dynamic loading for more intense performance over earlier products.
  • 6X tessellation
    More triangles means more details to give you more realistic environments.
  • Full destruction physics
    Environment reacts to gameplay to give you realistic destructibility.
  • Partially resident textures
    Preprocessed resident textures to free up GPU resources and take advantage of mega texturing.
  • Great performance
    GCN Architecture allows to achieve higher utilization for improved performance and efficiency.
  • Advanced performance optimization
    Accelerate your games and professional applications.
  • See the multi-monitor difference
    Improve your productivity from everyday task to professional workstation applications.
XFX Radeon R7 250 - graphics card - Radeon R7 250 - 2 GB
Graphics card - low profile
Graphics Engine
AMD Radeon R7 250
2 GB DDR3
Core Clock
1000 MHz
Boost Clock
1050 MHz
Stream Processors
384
Effective Memory Clock
1.6 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Resolution Details
HDMI: 4096 x 2160 / VGA: 2048 x 1536
Max Monitors Supported
2
DVI-D (Single-Link) , HDMI , VGA
API Supported
DirectCompute, OpenCL 1.2, OpenGL 4.3, DirectX 11.2
4.1 cm x 19 cm x 12.1 cm
Graphics Engine
AMD Radeon R7 250
Core Clock
1000 MHz
Boost Clock
1050 MHz
Stream Processors
384
Max Resolution
4096 x 2160
2
API Supported
Integrated 7.1 channel HD Audio controller, fanless heatsink, AMD HD3D Technology, AMD PowerPlay technology, AMD CrossFireX Technology, AMD PowerTune technology, AMD Catalyst technology, AMD Hybrid Graphics Technology, Enhanced Quality Anti-Aliasing (EQAA), Adaptive Anti-Aliasing, AMD HD Media Accelerator, Graphics Core Next (GCN), AMD ZeroCore Power technology, Blu-Ray 3D Support, Double Precision Floating Point, AMD App Acceleration 2, Intelligent TDP management technology, XFX Multi-Display Technology, Partially Resident Textures (PRT), cutting-edge integrated display support, 128-bit floating point HDR rendering, Multi-Stream Transport, AMD Unified Video Decoder (UVD), Advanced Video Color Correction, Morphological Anti-Aliasing (MLAA2), HDCP
Size
2 GB
DDR3 SDRAM
Effective Clock Speed
1.6 GHz
Bus Width
128-bit
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Windows 8.1
PSU Cross Marketing Insert
Software Included
Drivers & Utilities, AMD Catalyst Control Center
RoHS
4.1 cm
19 cm
12.1 cm
