XFX AMD Radeon R5 230 625MHz 1GB PCI-Express 3.0 HDMI
Quicklinx: 989ZWS00 Mfr#: R5-230A-ZLH2
  • High-Definition Multimedia Interface (HDMI)
  • Manufacturer: XFX
  • Chipset: Radeon R5 230
  • Core Clock: 625 MHz
  • Memory: 1GB
  • Memory Bit Rate: 64 Bit
  • Interface: PCIe 3.0 (x16)
  • Streams: 80
  • Cooling: Passive
  • Connectivity: 1 x D-Sub, 1 x Dual Link DVI-D, 1 x HDMI
  • Maximum Digital Resolution: 2560x1600
  • Maximum VGA Resolution: 2048x1536
  • Multi Monitor: 2 displays
  • Low Profile Support: Yes
  • Package Type: Retail
  • Next generation gaming graphics
    Fully supported Microsoft DirectX 11.2, with 4x faster tessellation rendering and massive virtual texture dynamic loading for more intense performance over earlier products.
  • Multi monitor daily productivity
    See all your programs at the same time without having to switch. Be more productive and get more done quickly.
  • Multi monitor professional audio editing
    See all your track, equalizers, samples and editors all the same time. Be more productive and get more done quickly.
  • Multi monitor gaming
    See more real-life peripheral vision around sides and see enemies you would have missed in single monitor.
XFX Radeon R5 230 - Core Edition - graphics card - Radeon R5 230 - 1 GB
Graphics card
Bus Type
PCI Express 2.1
Graphics Engine
AMD Radeon R5 230 - up to
1 GB DDR3
Core Clock
625 MHz
Stream Processors
80
Effective Memory Clock
1066 MHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / HDMI: 2560 x 1600 / VGA: 2048 x 1536
Interfaces Details
HDMI , DVI-D (dual link) , VGA
API Supported
DirectX 11.2
Fanless
1.41 cm x 17.2 cm x 6.88 cm
Graphics card - fanless
Bus Type
PCI Express 2.1
Graphics Engine
AMD Radeon R5 230
Core Clock
625 MHz
Stream Processors
80
Max Resolution
2560 x 1600
Interfaces Details
API Supported
DirectX 11.2
AMD HD3D Technology, AMD PowerPlay technology, AMD Unified Video Decoder (UVD) 3, AMD Hybrid Graphics Technology, 3rd Generation TeraScale Engine
Size
1 GB
DDR3 SDRAM
Effective Clock Speed
1066 MHz
Bus Width
64-bit
Required Power Supply
400 W
2 low-profile brackets
Software Included
Drivers & Utilities
RoHS
1.41 cm
17.2 cm
6.88 cm
