XFX AMD Radeon R5 230 2GB PCI-Express 3.0 HDMI
Quicklinx: 9KNVWS00 Mfr#: R5-230A-CNH2
  • High-Definition Multimedia Interface (HDMI)
The XFX AMD Radeon R5 230 graphics card delivers discrete graphics performance that's perfect for every day computing. Multitask with AMD's EyeSpeed technology and accelerate applications. Eyefinity technology lets you spread work across up to three displays so you can watch movies in vivid HD and multitask with impressive speed. With DirectX 11, the XFX AMD Radeon R5 230 graphics card gets a performance boost, delivering advance technologies with superb DirectX 11 support.
  • Next generation gaming graphics
    Fully supported Microsoft DirectX 11.2, with 4x faster tessellation rendering and massive virtual texture dynamic loading for more intense performance over earlier products.
  • Multi monitor daily productivity
    See all your programs at the same time without having to switch. Be more productive and get more done quickly.
  • Multi monitor professional audio editing
    See all your track, equalizers, samples and editors all the same time. Be more productive and get more done quickly.
  • Multi monitor gaming
    See more real-life peripheral vision around sides and see enemies you would have missed in single monitor.
XFX Radeon R5 230 - Core Edition - graphics card - Radeon R5 230 - 2 GB
Graphics card
Bus Type
PCI Express 3.0
Graphics Engine
AMD Radeon R5 230 - up to
2 GB DDR3
Core Clock
625 MHz
Stream Processors
80
Effective Memory Clock
1066 MHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / HDMI: 2560 x 1600 / VGA: 2048 x 1536
Interfaces Details
HDMI , DVI-D (dual link) , VGA
API Supported
DirectCompute 11, OpenGL 4.3, DirectX 11.2, Mantle
Fanless
1.88 cm x 16.8 cm x 11.2 cm
Graphics card - fanless
Bus Type
PCI Express 3.0
Graphics Engine
AMD Radeon R5 230
Core Clock
625 MHz
Stream Processors
80
Max Resolution
2560 x 1600
Interfaces Details
API Supported
Video Transcoding (AVT), AMD HD3D Technology, AMD PowerPlay technology, AMD Unified Video Decoder (UVD) 3, AMD Stream technology, Deep Color technology, 3rd Generation TeraScale Engine, Shader Model 5.0, Horizon-Based Ambient Occlusion (HBAO), HDR texture compression, GPU Tessellation
Size
2 GB
DDR3 SDRAM
Effective Clock Speed
1066 MHz
Bus Width
64-bit
Required Power Supply
400 W
2 low-profile brackets
Software Included
Drivers & Utilities
RoHS
1.88 cm
16.8 cm
11.2 cm
