The AMD Radeon HD 7800 series is the upgrade gamers deserve. Based on the GCN architecture, these cards are engineered for supremacy with the industry's very first 28 nm GPU design. Packed with incredible features, such as support for PCI Express 3.0, the ultra-efficient AMD ZeroCore Power technology and gaming at resolutions up to 7680 x 3200 with AMD Eyefinity technology, serious gaming starts here.
Ghost Thermal technology
Ghost Thermal technology is a floating cover design that maximizes airflow by creating exceptional venting through and out the card. -
Double Dissipation technology
Double Dissipation technology is unique dual fan design that allows cool all the heatsinks, components and the PCB board.
- XFX Radeon HD 7850 - Core Edition - graphics card - Radeon HD 7850 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon HD 7850
- Memory
- 2 GB GDDR5
- Core Clock
- 860 MHz
- Effective Memory Clock
- 4.8 GHz
- Memory Interface
- 256-bit
- Max Resolution
- 4096 x 3112
- Max Resolution Details
- DVI: 2560 x 1600 / DisplayPort: 4096 x 2160 / HDMI: 4096 x 3112 / VGA: 2048 x 1536
- Max Monitors Supported
- 4
- DVI-I (dual link) (HDCP) , DVI-D (Single-Link) (HDCP) , HDMI , 2 x Mini DisplayPort (Mini DisplayPort)
- API Supported
- DirectX 11, DirectCompute 11, OpenGL 4.2, OpenCL 1.2, Microsoft C++ AMP
- 3.81 cm x 19.8 cm x 11.12 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 860 MHz
- Process Technology
- 28 nm
- Max Resolution
- 4096 x 3112
- 4
- API Supported
- ATI CrossFire Technology, integrated HD Audio controller, AMD Eyefinity Technology, AMD HD3D Technology, AMD PowerPlay technology, AMD PowerTune technology, AMD Catalyst technology, ATI Unified Video Decoding (UVD), solid state capacitors, DTS-HD Master Audio support, Shader Model 5.0, Adaptive Anti-Aliasing, Morphological Anti-Aliasing (MLAA), Super-Sample Anti-Aliasing (SSAA), AMD HD Media Accelerator, Multi-Sample Anti-Aliasing (MSAA), AMD ZeroCore Power technology, Blu-Ray 3D Support, Double Precision Floating Point, HDR texture compression, AMD App Acceleration 2, Intelligent TDP management technology, XFX Bracket Design, accelerated multi-threading, 128-bit floating point HDR rendering, cutting-edge Quad HD display support, HDCP
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 4.8 GHz
- Bus Width
- 256-bit
- Required Power Supply
- 500 W
- Additional Requirements
- Adjacent PCI slot, PCIe slot, 6 pin PCI Express power connector
- Included Accessories
- CrossFire bridge, XFX Serial Number door hanger
- Software Included
- Drivers & Utilities
- 3.81 cm
- 19.8 cm
- 11.12 cm
