XFX AMD Radeon 7790 HD 1GB PCI-Express 3.0 HDMI Ghost Cooling
Quicklinx: 8N99WS00 Mfr#: FX-779A-ZNJ4
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
Specification
  • Chipset version - ATI Radeon HD 7790
  • GPU Clock - 1075 MHz
  • Memory Bus - 128 bit
  • Memory Clock - 6.4 GHz
  • Memory Size - 1 GB
  • Memory Type - DDR5
  • External Power - 6-Pins - 1
  • External Power - 8-Pins - 0
  • Minimum Power Supply Requirement - 450 watt
  • Output - Display Port - 1
  • Output - DL-DVI-D - 1
  • Output - DL-DVI-I - 1
  • Output - DMS-59 - 0
  • Output - HDMI - 1
  • Output - mini DP - 0
  • Output - mini HDMI - 0
  • Output - SL-DVI-D - 0
  • Output - SL-DVI-I - 0
  • Output - TV - 0
  • Output - VGA - 0
  • Thermal Solution - Ghost Thermal
  • Thermal Type - Dual slot
  • AMD - CrossFire ready - N
  • AMD Eyefinity Technology - Y
  • AMD HD3D Technology - Y
  • Display Port ready - 1.2
  • Double Dissipation Cooling Technology - N
  • Dual link Support - Y
  • Ghost Thermal Technology - Y
  • HDMI Ready - 1.4a
  • Hydrocell Thermal Solution - N
  • Low Profile Compatible - N
  • Max Supported Resolution (ANALOG) - 2048 x 1536
  • Max Supported Resolution (DIGITAL) - 2560 x 1600 (DVI) 4096 x 2160 (HDMI DP)
  • PowerTune - Y
  • XFX Recommended Power Supply - XFX 550W PSU
  • Card Profile - Dual
  • Duratec IP5X Dust Free - Y
  • Duratec Solid Capcitors - Y
  • Fan Ramping - Y
  • Double Dissipation technology
    XFX's unique dual fan design allows air to cool everything including thermal, GPU, heatsinks, components and the PCB board.
  • Multi monitor professional audio editing
    See all your tracks, equalizers, samples and editors all at the same time. Be more productive and get more done quickly.
  • Multi monitor professional video editing
    See all more of your time line at once and with a full screen preview. Be more productive and get more done quickly.
XFX Radeon HD 7790 - Core Edition - graphics card - Radeon HD 7790 - 1 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon HD 7790
1 GB GDDR5
Core Clock
1075 MHz
Effective Memory Clock
6.4 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Resolution Details
DVI: 2560 x 1600 / DisplayPort: 4096 x 2160 / HDMI: 4096 x 2160
Max Monitors Supported
6
DVI-I (dual link) , HDMI , DisplayPort , DVI-D (dual link)
API Supported
OpenGL 1.2, DirectCompute 11, OpenGL 4.2, DirectX 11.1
3.81 cm x 16.7 cm x 11.12 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon HD 7790
Core Clock
1075 MHz
Process Technology
28 nm
Max Resolution
4096 x 2160
6
API Supported
ATI CrossFire Technology, Avivo Technology, integrated 7.1 channel HD Audio controller, AMD HD3D Technology, AMD PowerPlay technology, AMD PowerTune technology, AMD Catalyst technology, AMD Stream technology, AMD Hybrid Graphics Technology, Dust-proof fan, solid state capacitors, Enhanced Quality Anti-Aliasing (EQAA), Shader Model 5.0, Adaptive Anti-Aliasing, Morphological Anti-Aliasing (MLAA), Super-Sample Anti-Aliasing (SSAA), AMD Eyefinity Technology 2.0, Ghost Thermal Technology, Multi-Sample Anti-Aliasing (MSAA), Digital Multi-Point Audio (DDMA), Graphics Core Next (GCN), AMD ZeroCore Power technology, Horizon-Based Ambient Occlusion (HBAO), Double Precision Floating Point, HDR texture compression, XFX Bracket Design, AMD App Acceleration 3, Partially Resident Textures (PRT), GPU Tessellation, accelerated multi-threading, Video Codec Engine (VCE), Multi-Stream Transport, HD/4k Ready, Double Dissipation cooling system, AMD Unified Video Decoder (UVD), HDCP
Size
1 GB
GDDR5 SDRAM
Effective Clock Speed
6.4 GHz
Bus Width
128-bit
Bandwidth
21.6 GBps
Required Power Supply
450 W
Additional Requirements
Adjacent PCI slot, 6 pin PCI Express power connector
XFX Serial Number door hanger, XFX BE badge
Software Included
Drivers & Utilities
3.81 cm
16.7 cm
11.12 cm
