XFX AMD Radeon 7750 HD 900MHz 1GB PCI-Express 3.0 HDMI
Quicklinx: 8F8LWS00 Mfr#: FX-775A-ZNJ4
  • High-Definition Multimedia Interface (HDMI)
Based on the award-winning GCN architecture, AMD Radeon HD 7700 series GPUs are built to destroy with the industry's very first 28 nm GPU design. Packed with incredible features, such as PCI Express 3.0, the ultra-efficient AMD ZeroCore Power technology or gaming at resolutions beyond 5760 x 1080 with AMD Eyefinity technology, these are advanced graphics. For everyone.
  • Core edition: benchmark core clock
    This card features XFX's unique standard GPU core at 800 MHz which is the benchmark core clock. Enjoy a great immersive gaming experience.
  • Maximize your gaming experience
    Multi-Monitor and stereoscopic 3D.
  • Next generation gaming graphics
    Ultra-Realistic 3D gaming with DirectX 11 technology.
  • Next generation performance
    A quantum leap in architecture and processing power, double the bandwidth.
  • Workstation grade performance
    Accelerating your professional applications.
  • See the multi-monitor difference
    Improve your productivity from everyday task to professional workstation applications
XFX Radeon HD 7750 - Core Edition - graphics card - Radeon HD 7750 - 1 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon HD 7750
1 GB GDDR5
Core Clock
800 MHz
Effective Memory Clock
4.5 GHz
Memory Interface
128-bit
Max Resolution
5760 x 1080
Max Resolution Details
DVI: 2560 x 1600 / HDMI: 4096 x 2160 / VGA: 2048 x 1536
Max Monitors Supported
4
DVI-D (dual link) , HDMI , VGA
API Supported
DirectX 11, DirectCompute 11, OpenGL 4.2, OpenCL 1.2, Microsoft C++ AMP
3.81 cm x 16.8 cm x 11.12 cm
Limited lifetime warranty with product registration
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon HD 7750
Core Clock
800 MHz
Max Resolution
5760 x 1080
4
API Supported
ATI CrossFire Technology, AMD Eyefinity Technology, AMD HD3D Technology, AMD PowerPlay technology, AMD PowerTune technology, AMD Catalyst technology, Dust-proof fan, solid state capacitors, Deep Color technology, Shader Model 5.0, Adaptive Anti-Aliasing, Morphological Anti-Aliasing (MLAA), Super-Sample Anti-Aliasing (SSAA), AMD HD Media Accelerator, Ghost Thermal Technology, Multi-Sample Anti-Aliasing (MSAA), Graphics Core Next (GCN), AMD ZeroCore Power technology, Horizon-Based Ambient Occlusion (HBAO), Double Precision Floating Point, HDR texture compression, AMD App Acceleration 2, Intelligent TDP management technology, XFX Bracket Design, Partially Resident Textures (PRT), accelerated multi-threading, 128-bit floating point HDR rendering, cutting-edge Quad HD display support, Video Codec Engine (VCE), Multi-stream hardware H.264 encoder, HD/4k Ready, Bullet Physics Engine, Ultra-high resolution texture streaming technology, AMD Unified Video Decoder (UVD)
Size
1 GB
GDDR5 SDRAM
Effective Clock Speed
4.5 GHz
Bus Width
128-bit
Microsoft Windows Vista / XP / 7
Required Power Supply
450 W
Additional Requirements
Adjacent PCI slot
XFX Serial Number door hanger, PSU Cross Marketing Insert
Software Included
Drivers & Utilities
3.81 cm
16.8 cm
11.12 cm
Limited warranty - lifetime
