The XFX AMD Radeon HD 6400 graphics card delivers discrete graphics performance that's perfect for every day computing. Multitask with AMD's EyeSpeed technology and accelerate applications. Eyefinity technology lets you spread work across up to three displays so you can watch movies in vivid HD and multitask with impressive speed. With DirectX 11, the XFX AMD Radeon HD 6400 graphics card gets a performance boost, delivering advance technologies with superb DirectX 11 support.
Passive cooling
XFX passive heatsinks are the perfect solution for a silent GPU environment. XFX design ensures optimal cooling fin arrangement, increasing the surface area and therefore radiating and dispersing heat more rapidly then other similar solutions. -
Microsoft DirectX 11
Get amazing eye-definition graphics with DirectX 11 technology. Featuring technologies like Compute Shaders, Direct2D, Multithreaded Rendering and Tessellation, DirectX 11 can enable not just more visually stunning games, but significant performance improvements in some of your favorite websites and everyday applications. -
AMD App Acceleration technology
Enjoy beautifully rich and clear video playback when streaming from the web, plus take in your favorite movies in stunning, stutter-free HD quality. Run multiple applications smoothly at maximum speed, and enjoy lightning fast game play and realistic physics effects.
- XFX Radeon HD 6450 Standard - graphics card - Radeon HD 6450 - 2 GB
- Graphics card - low profile
- Bus Type
- PCI Express 2.1 x16
- Graphics Engine
- AMD Radeon HD 6450
- Memory
- 2 GB DDR3
- Core Clock
- 625 MHz
- Effective Memory Clock
- 800 MHz
- Max Resolution
- 2560 x 1600
- API Supported
- DirectX 11, OpenGL 4.1
- 1.9 cm x 16.8 cm x 11.2 cm
- Bus Type
- Graphics Engine
- Core Clock
- 625 MHz
- Max Resolution
- 2560 x 1600
- API Supported
- Fanless heatsink, Video Transcoding (AVT), AMD HD3D Technology, AMD Accelerated Parallel Processing (APP) Technology, AMD PowerPlay technology, AMD CrossFireX Technology, AMD Unified Video Decoder (UVD) 3
- Size
- 2 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 800 MHz
- Required Power Supply
- 450 W
- 1.9 cm
- 16.8 cm
- 11.2 cm
