XFX AMD Radeon 6450 HD 2GB PCI-Express 2.1 HDMI
Quicklinx: 8N9CWS00 Mfr#: HD-645X-CNH2
  • High-Definition Multimedia Interface (HDMI)
The XFX AMD Radeon HD 6400 graphics card delivers discrete graphics performance that's perfect for every day computing. Multitask with AMD's EyeSpeed technology and accelerate applications. Eyefinity technology lets you spread work across up to three displays so you can watch movies in vivid HD and multitask with impressive speed. With DirectX 11, the XFX AMD Radeon HD 6400 graphics card gets a performance boost, delivering advance technologies with superb DirectX 11 support.
  • Passive cooling
    XFX passive heatsinks are the perfect solution for a silent GPU environment. XFX design ensures optimal cooling fin arrangement, increasing the surface area and therefore radiating and dispersing heat more rapidly then other similar solutions.
  • Microsoft DirectX 11
    Get amazing eye-definition graphics with DirectX 11 technology. Featuring technologies like Compute Shaders, Direct2D, Multithreaded Rendering and Tessellation, DirectX 11 can enable not just more visually stunning games, but significant performance improvements in some of your favorite websites and everyday applications.
  • AMD App Acceleration technology
    Enjoy beautifully rich and clear video playback when streaming from the web, plus take in your favorite movies in stunning, stutter-free HD quality. Run multiple applications smoothly at maximum speed, and enjoy lightning fast game play and realistic physics effects.
XFX Radeon HD 6450 Standard - graphics card - Radeon HD 6450 - 2 GB
Graphics card - low profile
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD Radeon HD 6450
2 GB DDR3
Core Clock
625 MHz
Effective Memory Clock
800 MHz
Max Resolution
2560 x 1600
API Supported
DirectX 11, OpenGL 4.1
1.9 cm x 16.8 cm x 11.2 cm
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD Radeon HD 6450
Core Clock
625 MHz
Max Resolution
2560 x 1600
API Supported
Fanless heatsink, Video Transcoding (AVT), AMD HD3D Technology, AMD Accelerated Parallel Processing (APP) Technology, AMD PowerPlay technology, AMD CrossFireX Technology, AMD Unified Video Decoder (UVD) 3
Size
2 GB
DDR3 SDRAM
Effective Clock Speed
800 MHz
Required Power Supply
450 W
1.9 cm
16.8 cm
11.2 cm
