Xerox WorkCentre 6605VDN Colour Laser Multifunction Printer
Quicklinx: 8QP9WS00 Mfr#: 6605V_DN
With the value-packed WorkCenter 6605 color multifunction printer, today's busy, small workteams can easily make important business communications stand out from the competition with exceptional color printing.
  • Print quality
    A print resolution of up to 600 x 600 x 4 dpi makes your printed communications stand out and grab attention. Photo Mode makes your images and graphics look exceptional, producing deeper, richer colors for lifelike vibrancy. Unique Xerox EA Toner fuses at a much lower temperature, and reduces power consumption by up to 20% and CO2 emissions by up to 35%, compared to conventional toner. It's also oil-free, delivering brilliant, glossy output, even on ordinary or recycled paper. Pantone Color calibrated solid-color simulations and Xerox color correction technology ensure results that match your expectations.
  • Productivity and reliability
    A fast print speed of up to 36 ppm means your documents are always ready when you need them. The main 550-sheet paper tray holds a full ream of paper. An optional 2nd tray increases total capacity up to 1250 sheets for even longer periods of uninterrupted productivity.
  • Ease-of-use
    The innovative 4.3-inch touch screen features bright, colorful icons and intuitive navigation for optimal ease-of-use. Use the WorkCenter 6605 to scan your hard copy documents and get text-searchable digital files that can be automatically shared via email or network folder, or saved on the device or any USB memory device for true portability. The WorkCenter 6605 is simple to install on your office network, getting you up and running in minutes.
Xerox WorkCentre 6605DN - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
80000 impressions
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 35 ppm (mono) / up to 35 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Data Compression System
MH, MR, MMR, JBIG, JPEG
Display
4.3"
Original Size
140 x 140 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, labels
Standard Media Capacity
700 sheets
Max Media Capacity
1250 sheets
Bypass Feeder Capacity
150 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to network
AC 230 V (50/60Hz)
43 cm x 52.8 cm x 56 cm
32.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
EPEAT Silver, ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - colour
80000 impressions
Display Diagonal Size
4.3"
Display Features
Touch screen
Standard Memory
512 MB 512 MB
Max Supported Memory
1 GB 1 GB
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
2 on 1, fit to page, Clone Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PDF, XPS, PCL 5
Automatic Duplexing
First Print Out Time B/W
9 sec
First Print Out Time Colour
10 sec
Colour Management Features
PANTONE Digital Color
Scanning
Automatic Duplexing
Fax Machine
Fax Machine Features
Speed Dialing
200 station(s)
Broadcast Transmission
Delayed Transmission
Fax forwarding, Distinctive Ring Pattern Detection (DRPD), junk fax barrier, LAN fax, poll receive
Document & Media Handling
Min Original Size
140 x 140 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
50 g/m²
Max Media Weight
216 g/m²
Supported Media Type
Supported Media Sizes
700 sheets
Max Media Capacity
1250 sheets
150 sheets
250 sheets
ADF - 50 sheets size: 140 x 140 mm - Legal (216 x 356 mm) weight: 50 g/m² - 125 g/m² , Bypass tray - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Input tray - 550 sheets size: A5 (148 x 210 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Output tray - 250 sheets
Speed Details
Printing: up to 35 ppm (A4) - B/W , Printing: up to 35 ppm (A4) - B/W
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Network Protocols
SNMP, HTTPS, IPv6, Bonjour
Security Protocols & Features
LDAP, Secure Print, SSL, IPsec, 802.1x, Secure Fax, IP filtering
Operating System Support
UNIX, Linux, MS Windows XP or later, Apple Mac OS X 10.5 or later
Software Included
Xerox CentreWare Web, Xerox CentreWare Internet Services, Xerox Email Alerts
AC 230 V (50/60Hz)
560 Watt
Power Consumption Standby
72 Watt
Power Consumption Sleep
6 Watt
Warm-Up Time
25 sec
First Copy Out Time B/W
13 sec
First Copy Out Time Colour
16 sec
Consumables Included
1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - 1 year - on-site
43 cm
52.8 cm
56 cm
32.5 kg
Sound Emission
29 dBA (idle) / 52 dBA (operating)
10 °C
32 °C
10 - 85% (non-condensing)
Ink (5)
8QP9 Xerox 6600 High Capacity Black Toner 8K In Stock £129.66
8QP9 Xerox 6600 High Capacity Yellow Toner 6K In Stock £181.59
8QP9 Xerox 6600 High Capacity Magenta Toner 6K In Stock £179.13
8QP9 Xerox 6600 High Capacity Cyan Toner 6K In Stock £179.13
8QP9 Xerox 6600 Imaging Drum Unit In Stock £244.97
Other bundles (2)
8QP9 Xerox 550 Sheet Tray for Phaser 6600 In Stock £331.45
8QP9 Xerox Waste Toner Collector for Phaser 6600 In Stock £24.16
