Your busy work-team needs a value-packed color device that gets the job done with the rare combination of outstanding print quality, unparalleled simplicity and day-in, day-out dependability. The WorkCentre 6505 color multifunction printer gives your important documents a powerful, colorful boost. A high print resolution makes your printed communications stand out and grab attention. Xerox exclusive toner uses particles engineered for uniform size and shape, producing superior image detail and line de?nition, and text that's sharp and clear. Pantone Color approved solid-color simulations and Xerox color correction technology ensure results that match your expectations.
Connect and go, thanks to built-in networking and seamless compatibility with mixed-user environments, including PC, Macintosh and Linux. With Xerox CentreWare IS, remote device administration is handled with ease right from your computer's browser. The device features a small footprint, which allows for easy integration within your work space, whether on your desk or in a shared location. The value-packed WorkCentre 6505 multifunction printer will save on energy and supplies costs by combining the functions of multiple devices into one.
WorkCentre 6505
The Xerox WorkCentreTM 6505 colour multifunction printer. Today's busy workteams need a value-packed colour device that handles all of your printing needs with that rare combination of outstanding print quality, unparalleled simplicity, and day-in, day-out dependability. Get total peace of mind with our one-year, on-site warranty. -
Quick Facts
•Colour: up to 23 ppm • Black: up to 23 ppm • Maximum paper size: 216 x 356 mm • Standard paper capacity: Tray 1: 250 sheets • Maximum paper capacity: 500 sheets • Automatic document feeder: 35 sheets • 533 MHz processor • 256 MB memory standard, 768 MB maximum • Windows (including Windows 7) and Mac compatible • Minimum dimensions (w x d x h): 430 x 544.2 x 584.4 mm • Power requirements: 240 V, 50/60 Hz • What comes in the box • Colour and black print cartridges (capacity: 1,000 pages each1) • Scan to PC Desktop CD (Nuance PaperPort, ImageRetriever, OmniPage) • Power cord • Fax cable • Software and documentation -
Productivity Features
•The value-packed WorkCentre 6505 colour multifunction printer means serious business for your workteam, providing real-world MFP capabilities and a host of built-in features • Superior performance gets your jobs out quickly, with colour and black-and-white print speeds up to 23 ppm • Powerful scanning capabilities include Scan to Email, Network Scanning, Direct Scan to Applications including Optical Character Recognition, and Scan to USB memory device • Standard copy features include ID Card Copy, N-up, auto fit, cloning, collate and more • Send faxes from the network using LAN Fax, or take advantage of full walkup fax features such as speed dial, remote receive and fax broadcast • A powerful 533 MHz processor and 256 MB standard memory handle your workteam's demanding workload - including multipage print jobs with graphics, photos and charts -
Print Quality Features
•A print resolution of up to 600 x 600 x 4 dpi delivers an amazing 16 shades of colour per pixel. That means a wider colour range for more expressive business graphics • Unique Xerox EA toner technology gives you crisp text and printed images with superior detail and clarity. It's the same high-quality toner used in our professional graphic-arts colour devices • True Adobe PostScript 3 means you can count on consistently precise print jobs with bright, true colours and superior graphics • PANTONE Colour approved solid-colour simulations and Xerox colour correction technology provide easy tools for precisely matching the colours of important business assets, such as company logos -
Reliability and Ease-of-use Features
•The intuitive LCD user interface makes it fast and easy to configure device settings and program jobs • A front-side USB port allows users to quickly print from or scan to any standard USB memory device • A 35-sheet automatic document feeder handles media sizes from 139.7 x 139.7 mm to 216 x 356 mm • The CentreWare IS internal web server makes it easy to handle device administration right from your computer's browser • Outstanding reliability is backed by Xerox with a one-year on-site warranty • Easy installation and pre-loaded toner cartridges make this printer virtually plug-and-play • Simple supplies replacement via convenient side door access • The Run Black feature lets you keep printing in black-and-white even if the printer runs out of colour toner -
Environment-friendly Features
•Print more, use less. Whether you choose manual two-sided printing, or upgrade to convenient automatic duplexing, you'll conserve paper for reduced costs and increased sustainability • With minimal packaging, our toner-only cartridges allow for 80% less waste than comparable colour devices using integrated print cartridges, and also let you easily store backup toner in a desk drawer • A small footprint allows for easy integration within your work space, whether on your desk or in a shared location • Extra-quiet operation to minimize impact on busy offices 1 Average standard pages. Declared Yield in accordance with ISO/IEC 19798. Yield will vary based on image, area coverage and print mode.
- Xerox WorkCentre 6505N - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 40000 impressions
- Max Copying Speed
- Up to 23 ppm (mono) / up to 23 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG, JPEG
- Fax Resolutions
- 400 x 400 dpi
- Scanning
- 1200 x 1200 dpi
- Original Size
- 140 x 140 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets, books
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, cards, labels
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 500 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Optional (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail
- Power
- AC 230 V (50/60Hz)
- 43 cm x 54.4 cm x 58.4 cm
- 28.4 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- EPEAT Silver, ENERGY STAR Qualified
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - colour
- 40000 impressions
- Interface
- Standard Memory
- 256 MB 256 MB
- Max Supported Memory
- 768 MB 768 MB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Copying Features
- Fit to page, ID Card Copy, Clone Copy
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3
- Image Enhancement Technology
- 4-bit depth colour technology
- Optional
- First Print Out Time B/W
- 12 sec
- First Print Out Time Colour
- 12 sec
Scanning
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 400 x 400 dpi
Fax Machine Features
- Broadcast Transmission
- Delayed Transmission
- Fax forwarding, e-mail function, colour faxing, LAN fax
Document & Media Handling
- Min Original Size
- 140 x 140 mm
- Max Original Size
- Original Type
- Sheets, books
- 35 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 216 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
- 250 sheets
- 500 sheets
- 1 sheet
- 150 sheets
- ADF - 35 sheets size: 140 x 140 mm - Legal (216 x 356 mm) weight: 50 g/m² - 125 g/m² , Bypass tray - 1 sheet size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Input tray - 250 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 23 ppm (A4) - B/W , Printing: up to 23 ppm (A4) - colour
- 1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
- Network Protocols
- TCP/IP
- SSL, IPsec, 802.1x, Secure Fax
- Operating System Support
- MS Windows XP, MS Windows Server 2003, Apple Mac OS X 10.5, MS Windows 7, MS Windows Vista, MS Windows Server 2008
- Software Included
- ScanSoft PaperPort, ScanSoft OmniPage, Nuance Image Retriever
- Voltage Required
- 425 Watt
- Power Consumption Standby
- 65 Watt
- Power Consumption Sleep
- 18.4 Watt
- Warm-Up Time
- 31 sec
- First Copy Out Time B/W
- 13 sec
- First Copy Out Time Colour
- 20 sec
- Included Accessories
- Phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 1000 pages , 1 x toner cartridge (magenta) - up to 1000 pages , 1 x toner cartridge (yellow) - up to 1000 pages
- GOST, GS, NOM, FCC Part 15 B, EMC, R&TTE, UL 60950-1, CSA C22.2 No. 60950-1-07, Section 508
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- 43 cm
- 54.4 cm
- 58.4 cm
- 28.4 kg
- Sound Emission
- 22 dBA (idle) / 52 dBA (operating)
- 10 °C
- 32 °C
- 10 - 85% (non-condensing)
