The compact WorkCentre 6027 Color Multifunction Printer excels in small office environments where high-impact color, speed, Wi-Fi connectivity and ease of use are priorities. With efficient print, copy, scan, fax and email functions on one device, you can get your work done quickly, without a second thought.
Automatically feed documents
Save time copying and scanning multiple-page documents with the 15-sheet Automatic Document Feeder. -
Speedy faxing
The WorkCentre 6027 Multifunction Color LED Printer comes packed with the most common fax capabilities at a speed of 33.6 Kbps. -
Accomplish more and spend less time waiting
The WorkCentre 6027 Multifunction Color LED Printer features a print speed of 18 ppm in color and 18 ppm black-and-white and provides color prints in less than 13 seconds. -
Plenty of power
The powerful 525 MHz processor and generous amount of standard memory handle your daily workload with ease, including pages full of graphics, photos and charts. -
Superior image quality
The 1200 x 2400 dpi enhanced image quality delivered by the Hi-Q LED print engine provides high resolution color printing with precise image alignment and fantastic detail. -
Color your way
Last-minute color adjustments are a snap for both the expert and novice user with powerful, easy-to-use controls in the Xerox printer driver. -
Color touchscreen
The large, intuitive 109 mm color touchscreen user interface makes complicated tasks simple. -
Convenient USB port
The WorkCentre 6027 Multifunction Color LED Printer's front-side USB port allows you to print from, or scan to, any standard, portable USB memory device. -
Streamline processes
Powerful features simplify tasks for small offices, including the Paper Setup Navigator, taking the guesswork out of printing on custom paper sizes and types from plain office paper to envelopes and labels. -
Print from anywhere
Connect without the need for network cabling with standard built-in Wi-Fi, featuring one-touch setup. Simply press the WPS button on the printer, then the WPS button on your Wi-Fi enabled router, and then work and print from anywhere. -
Connectivity simplified
With Wi-Fi Direct, mobile phones, tablets, and laptop computers can make a secure connection directly to the multifunction printer even if you don't have an existing wireless network.
- Xerox WorkCentre 6027V_NI - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- LED (colour)
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 1500 pages
- Max Copying Speed
- Up to 18 ppm (mono) / up to 18 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 2400 dpi (mono) / up to 1200 x 2400 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi, 406 x 392 dpi
- Scanning
- 600 x 600 dpi
- Display
- 4.3"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 15 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, card stock, light-weight paper, glossy paper
- Standard Media Capacity
- 150 sheets
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to network
- Power
- AC 230 V (50/60Hz)
- 41 cm x 43.9 cm x 38.8 cm
- 16.9 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Fax Type
- Plain paper
- LED - colour
- 30000 pages
- 1500 pages
- Display Diagonal Size
- 4.3"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 512 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- Fit to page, ID Card Copy, collation copy, Edge Erase
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF, TIFF
- First Print Out Time B/W
- 12 sec
- First Print Out Time Colour
- 13 sec
- Colour Management Features
- PANTONE Digital Color
Scanning
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
Fax Machine Features
- One-Touch Dialing
- 8 station(s)
- Delayed Transmission
- Fax forwarding, automatic redialing, group dialling, auto reduction
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 15 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- 150 sheets
- 100 sheets
- ADF - 15 sheets size: A5 (148 x 210 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 18 ppm (A4) - B/W , Printing: up to 18 ppm (A4) - colour , Copying: up to 18 ppm (A4) - B/W , Copying: up to 18 ppm (A4) - colour , Scanning: up to 14 ipm (A4) - B/W , Scanning: up to 9 ipm (A4) - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- SSL, WEP, WPA, WPA2, IPsec, WPA2-PSK, WPS, IP filtering, Wi-Fi Direct, TTLS
- Operating System Support
- Apple Mac OS X 10.6.x, Apple Mac OS X 10.5.8, Apple Mac OS X 10.7.x, MS Windows Server 2008 R2 x64 Edition, Ubuntu Linux 12.04, Apple Mac OS X 10.8.x, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, Red Hat Enterprise Linux 6 Desktop, Windows 8.1, Windows 8.1 64-bit, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, Apple Mac OS X 10.9.x, MS Windows XP (32/64 bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), SUSE Linux Enterprise Desktop 11 (32/64-bit)
- Voltage Required
- 330 Watt
- Power Consumption Standby
- 45 Watt
- Power Consumption Sleep
- 3.5 Watt
- First Copy Out Time B/W
- 20 sec
- First Copy Out Time Colour
- 30 sec
- Included Accessories
- USB cable
- Consumables Included
- 1 x toner cartridge (black) - up to 500 pages , 1 x toner cartridge (cyan) - up to 500 pages , 1 x toner cartridge (magenta) - up to 500 pages , 1 x toner cartridge (yellow) - up to 500 pages
- EN55024, EN55022 Class B, EN 60950-1 Second Edition, Directive 2012/19/EU, Directive 2011/65/EU, EMC 2004/108/EC, LVD 2006/95/EC, IEC 60950-1:2005 Second Edition
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year - on-site
- 41 cm
- 43.9 cm
- 38.8 cm
- 16.9 kg
- Shipping Width
- 56.7 cm
- Shipping Depth
- 54.1 cm
- Shipping Height
- 53.3 cm
- Shipping Weight
- 19.9 kg
- Sound Emission
- 21.9 dBA (idle) / 49.1 dBA (operating)
- 10 °C
- 32 °C
- 10 - 85%
